B body control arms
#2930782
06/07/21 09:01 AM
06/07/21 09:01 AM
Posts: 938 White House,TN
stroked470
White House,TN
Does anyone have a recommendation for upper control arms for a B body. I need to get more caster. I had it lined up yesterday, It was driving terrible at anything over 40 mph. The caster was at -2.5 but the camber and toe were good. He was able to get the caster around +2 but he couldn't the camber to come in and keep the caster in the +. I have seen several control arms that say 3-5 degrees of caster built in and they are non-adjustable. Would I be better to use the adjustable or non-adjustable. Mainly a streetcar but it will be going to the track a couple times a year. I want to be able to drive it as much as possible. It is a 68 Sport Satelite Convertible. I forgot to add. all of the front suspension has been rebuilt. would a adjustable strut rod get me a couple of degrees to where i can just adjust the eccentrics back to where they were instead of changing the upper control arms.
Re: B body control arms
[Re: stroked470]
#2930867
06/07/21 12:57 PM
06/07/21 12:57 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
I do have the print out at home. The current control arms are factory. The front end was recently rebuilt when I bought it about 8 months ago. I am not sure what parts were used other them everything come from PST. The reason I asked is because I was having trouble getting mine dialed in as well. It almost looks like the upper ball joints are too tall in my case. Jeff
[Re: stroked470]
#2931054
06/07/21 07:57 PM
06/07/21 07:57 PM
Posts: 12,165 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
WOW! $480 for a pair?!?!? Is that right?
Master, again and still
[Re: DaveRS23]
#2931165
06/08/21 07:58 AM
06/08/21 07:58 AM
Posts: 164 W. Pa
usp4u
W. Pa
WOW! $480 for a pair?!?!? Is that right? They're worth double that, IMO.
