Page 1 of 3 1 2 3
Choosing a torque converter #2929054
06/01/21 03:42 AM
06/01/21 03:42 AM
Chino Valley
B300 VanDanage Offline OP
Chino Valley
I have a stock A727 powered by a stock LA360 2bbl...
I'm having trouble finding a low stall converter for my application.
It's an extended cargo van and I plan on using it to pull some cars on a dolly every now and then so a little medium to heavy towing... Maybe also weighed down with tools and provisions.
I'm pretty much going to keep the motor stock. I was thinking maybe I'll get a new carb and some headers later on but not much of a difference.
I am currently rebuilding my 727 and the converter it had is a Pro King cr25l from AutoZone. I had the tranny rebuilt at a shop a couple of years ago and the converter failed after about 10000 miles. I took it back to the same shop and they rebuilt it again using the Pro King cr25l converter.
Long story short I installed it myself and had some issues with alignment and reverse so I'm rebuilding it myself and now need help choosing a converter.
I've spent over $3000 now on this tranny so I don't want to spend much more but I also don't want the cheap one from auto zone.
What's a good converter with a stall around 1775-2075 that'll work for my application?
I found a B&M 10416 Tork Master 2000 that's around $250 and that'll require a different flex plate. The Tork Master has a stall speed of 1800-2100... Are these good converters?
will this work for my application and are there any similar converters out there that might work better for around the same price?
Thanks for the help!
Re: Choosing a torque converter [Re: B300 VanDanage] #2929058
06/01/21 06:17 AM
06/01/21 06:17 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Fortunately you are in a stall range where the price is affordable. I know many transmission shops use a company called Dayco.
Keep old mopars alive.
Re: Choosing a torque converter [Re: 2boltmain] #2929074
06/01/21 08:12 AM
06/01/21 08:12 AM
BDW Offline
BDW  Offline
I used a Pro King from Advanced when I put in my 518, no complaints 4 years later.
Re: Choosing a torque converter [Re: 2boltmain] #2929143
06/01/21 11:39 AM
06/01/21 11:39 AM
Chino Valley
Chino Valley
Dayco or Dacco? Because I couldn't find anything under the name Dayco...
Re: Choosing a torque converter [Re: BDW] #2929148
06/01/21 11:49 AM
06/01/21 11:49 AM
Chino Valley
Chino Valley
Advanced doesn't carry Pro King, at least not anymore? I searched on their website and all I get for my vehicle are $500 Hayes converters. I'm not trying to spend more than $300 for a converter!
I'm sure the Pro King will be fine but... If I can spend 100 - 200 more then for something way better I'd rather do that...
Re: Choosing a torque converter [Re: B300 VanDanage] #2929149
06/01/21 11:51 AM
06/01/21 11:51 AM
Chino Valley
Chino Valley
Anyone familiar with B&M converters?
I'm really leaning towards the Tork Master 2000...
So here are my options so far:
Pro King cr25l. $89
B&M 10416 Tork Master 2000. $260 plus $100 flex plate
Torco 764HD $177
After looking into it I've found that Torco is actually a really good company and make a quality converter... If this converter bolts to the stock flex plate I think it'll be the one...
Re: Choosing a torque converter [Re: 2boltmain] #2929155
06/01/21 12:18 PM
06/01/21 12:18 PM
Chino Valley
Chino Valley
There's a note under the tc remain converter in the autozone website that says Dacco isn't supplying converters anymore.
Re: Choosing a torque converter [Re: B300 VanDanage] #2929170
06/01/21 01:36 PM
06/01/21 01:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For a 360-2 van pulling heavy loads I would go to a 12" converter...less slippage, less heat buildup.
The Dacco has the correct external weight and uses the stock factory flexplate but you'll have change from the 11" flexplate.
Re: Choosing a torque converter [Re: John_Kunkel] #2929195
06/01/21 03:08 PM
06/01/21 03:08 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I have had very good success with TCI converters. They have stock stall speeds and good selection in the $375-$400 range for HP converters though so I don't know if that's more than you're looking at
https://www.tciauto.com/torque-converters/street-street-rodder.html
Facts are stubborn things.
Re: Choosing a torque converter [Re: John_Kunkel] #2929203
06/01/21 03:25 PM
06/01/21 03:25 PM
Chino Valley
Chino Valley
Hmmm, didn't know I could go with a bigger converter...
Had I known I would've expanded my search criteria...
I actually just ordered the Torco 764HD with a stall speed of 1800-2100 for $195 shipped! They have a good reputation and for the price I think it was a good choice.
If I had a little more patience I would've probably searched around a bit more but...
I appreciate the info!
Re: Choosing a torque converter [Re: larrymopar360] #2929206
06/01/21 03:28 PM
06/01/21 03:28 PM
Chino Valley
Chino Valley
Yea that's a little more then I'd like to spend...
I went with the Torcco 764HD with stall of 1800-2100 and all for just $200...
Thanks for the suggestion!
Re: Choosing a torque converter [Re: B300 VanDanage] #2929480
06/02/21 01:12 PM
06/02/21 01:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does that converter have the necessary external balance weights?
Re: Choosing a torque converter [Re: John_Kunkel] #2929489
06/02/21 01:29 PM
06/02/21 01:29 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
As John says or a scalloped flex plate B&M 10236
Re: Choosing a torque converter [Re: B300 VanDanage] #2929581
06/02/21 06:40 PM
06/02/21 06:40 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I wanted that Tork master for my 727 behind the slant6 I'm building for my D150 until I found out that my current 727 is a lock up version, nobody makes/builds a converter for a lockup besides "stock replacement".
Re: Choosing a torque converter [Re: volaredon] #2929594
06/02/21 07:08 PM
06/02/21 07:08 PM
A727Tflite Offline
A727Tflite  Offline
The Mopar Reman line of converters are some of the best out there if they have what you need. When it comes to lockup they are the best,
As close to new as you can get.
You would be surprised what some of the aftermarket converters don’t get when they are built.
Some get nothing more than cut open, cleaned, inspected and put back together.
Re: Choosing a torque converter [Re: A727Tflite] #2929601
06/02/21 07:22 PM
06/02/21 07:22 PM
BDW Offline
BDW  Offline
The Mopar Reman line of converters are some of the best out there if they have what you need. When it comes to lockup they are the best. [/quote]
Is there a website to check options, or have to call dealership?
Re: Choosing a torque converter [Re: BDW] #2929605
06/02/21 07:34 PM
06/02/21 07:34 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Good point Transman I forgot about lockup, although that year might be electronic and easily disconnected? And I did not know that about the quality of theirs. up
Re: Choosing a torque converter [Re: BDW] #2929629
06/02/21 08:47 PM
06/02/21 08:47 PM
A727Tflite Offline
A727Tflite  Offline
Is there a website to check options, or have to call dealership? [/quote]
A dealer with a good parts counter guy will be your best bet. I’ll see if I can scare up some part numbers for you.
What application are you looking for ?
Re: Choosing a torque converter [Re: John_Kunkel] #2929639
06/02/21 08:59 PM
06/02/21 08:59 PM
Chino Valley
Chino Valley
I really hope so! It says fully balanced in the description... No picture of the front cover...
Re: Choosing a torque converter [Re: larrymopar360] #2929642
06/02/21 09:04 PM
06/02/21 09:04 PM
Chino Valley
Chino Valley
What do you mean?
If it doesn't have the external weight I'll be able to buy the B&M flex plate to resolve that issue?
Page 1 of 3 1 2 3
