Re: Choosing a torque converter
[Re: B300 VanDanage]
#2929058
06/01/21 06:17 AM
06/01/21 06:17 AM
Posts: 4,788 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Fortunately you are in a stall range where the price is affordable. I know many transmission shops use a company called Dayco.
Keep old mopars alive.
#2929149
06/01/21 11:51 AM
06/01/21 11:51 AM
Posts: 335 Chino Valley
B300 VanDanage
Chino Valley
Anyone familiar with B&M converters? I'm really leaning towards the Tork Master 2000...
So here are my options so far:
Pro King cr25l. $89
B&M 10416 Tork Master 2000. $260 plus $100 flex plate
Torco 764HD $177
After looking into it I've found that Torco is actually a really good company and make a quality converter... If this converter bolts to the stock flex plate I think it'll be the one...
[Re: 2boltmain]
#2929155
06/01/21 12:18 PM
06/01/21 12:18 PM
B300 VanDanage
Chino Valley
Fortunately you are in a stall range where the price is affordable. I know many transmission shops use a company called Dayco. There's a note under the tc remain converter in the autozone website that says Dacco isn't supplying converters anymore.
#2929170
06/01/21 01:36 PM
06/01/21 01:36 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
For a 360-2 van pulling heavy loads I would go to a 12" converter...less slippage, less heat buildup.
The Dacco has the correct external weight and uses the stock factory flexplate but you'll have change from the 11" flexplate.
[Re: John_Kunkel]
#2929203
06/01/21 03:25 PM
06/01/21 03:25 PM
B300 VanDanage
Chino Valley
The Dacco has the correct external weight and uses the stock factory flexplate but you'll have change from the 11" flexplate. Hmmm, didn't know I could go with a bigger converter... Had I known I would've expanded my search criteria... I actually just ordered the Torco 764HD with a stall speed of 1800-2100 for $195 shipped! They have a good reputation and for the price I think it was a good choice. If I had a little more patience I would've probably searched around a bit more but... I appreciate the info!
[Re: larrymopar360]
#2929206
06/01/21 03:28 PM
06/01/21 03:28 PM
B300 VanDanage
Chino Valley
Yea that's a little more then I'd like to spend... I went with the Torcco 764HD with stall of 1800-2100 and all for just $200... Thanks for the suggestion!
#2929480
06/02/21 01:12 PM
06/02/21 01:12 PM
John_Kunkel
Rio Linda, CA
Does that converter have the necessary external balance weights?
[Re: John_Kunkel]
#2929489
06/02/21 01:29 PM
06/02/21 01:29 PM
Posts: 15,934 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Does that converter have the necessary external balance weights? As John says or a scalloped flex plate B&M 10236
Facts are stubborn things.
[Re: volaredon]
#2929594
06/02/21 07:08 PM
06/02/21 07:08 PM
Posts: 3,092 Michigan
A727Tflite
I wanted that Tork master for my 727 behind the slant6 I'm building for my D150 until I found out that my current 727 is a lock up version, nobody makes/builds a converter for a lockup besides "stock replacement". The Mopar Reman line of converters are some of the best out there if they have what you need. When it comes to lockup they are the best, As close to new as you can get. You would be surprised what some of the aftermarket converters don’t get when they are built. Some get nothing more than cut open, cleaned, inspected and put back together.
[Re: BDW]
#2929629
06/02/21 08:47 PM
06/02/21 08:47 PM
A727Tflite
The Mopar Reman line of converters are some of the best out there if they have what you need. When it comes to lockup they are the best. Is there a website to check options, or have to call dealership? [/quote] A dealer with a good parts counter guy will be your best bet. I’ll see if I can scare up some part numbers for you. What application are you looking for ?
[Re: John_Kunkel]
#2929639
06/02/21 08:59 PM
06/02/21 08:59 PM
B300 VanDanage
Chino Valley
Does that converter have the necessary external balance weights? I really hope so! It says fully balanced in the description... No picture of the front cover...
[Re: larrymopar360]
#2929642
06/02/21 09:04 PM
06/02/21 09:04 PM
B300 VanDanage
Chino Valley
Does that converter have the necessary external balance weights? As John says or a scalloped flex plate B&M 10236 What do you mean? If it doesn't have the external weight I'll be able to buy the B&M flex plate to resolve that issue?
