Purple cam 2402722 #2925878
05/23/21 04:01 PM
05/23/21 04:01 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
This cam has some purple showing and the number 2402722 is cast into the cam. What do I have?
2402 numbers are on a lot of max wedge parts. ?? Thanks.
Re: Purple cam 2402722 [Re: MO_PA] #2926012
05/23/21 10:41 PM
05/23/21 10:41 PM
Mopar has never I.D their Hi Po after market cams with casting numbers or part #s etched into the ends puke down
the only way I know of finding out which version of their cams you have is to install it into a block and degree it and hope you have a true Mopar brand cam and not some other better brand with some purple paint someone slop on it scope luck
Re: Purple cam 2402722 [Re: Cab_Burge] #2926053
05/24/21 08:22 AM
05/24/21 08:22 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you could measure a lobe with a set of calipers and get an idea of what the lobe lift is and go from there. that number doesn't match up to the 300-308/.520 max wedge cam info i have.
Re: Purple cam 2402722 [Re: lewtot184] #2926070
05/24/21 09:12 AM
05/24/21 09:12 AM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
The number is not on the end it's between the rear bearing and the back lobe,
it is not stamped or etched but it's like a casting number in reverse
I've seen dozens of Mopar cams but this is something new to me. The number 2402722
makes me think it is max wedge related. I'll do some measuring.
Re: Purple cam 2402722 [Re: MO_PA] #2926252
05/24/21 06:46 PM
05/24/21 06:46 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I measured this cam and it's a 'baby', certainly not a max wedge cam.
