541 stroker update. Stuffing it in there. #2925371
05/22/21 01:04 AM
05/22/21 01:04 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I finally got the time to stuff some video bits together to show the clearancing needed when stuffing a 4.5" crank in a 440. Working full time, working my side business, and lots of medical drama (family and friends) I haven't had much spare time so the progress has been a bit slow.
Have a looksie if you're interested in a 540+ inch RB build.
- Stu Harmon
Re: 541 stroker update. Stuffing it in there. [Re: feets] #2925404
05/22/21 08:27 AM
05/22/21 08:27 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Re: 541 stroker update. Stuffing it in there. [Re: Hugh Jorgan] #2927967
05/29/21 08:15 AM
05/29/21 08:15 AM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
Good info thanks for sharing up
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: 541 stroker update. Stuffing it in there. [Re: adventurer] #2928171
05/29/21 03:26 PM
05/29/21 03:26 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Your build is along the same lines as mine, except you manned up for the bigger stroke than I was prepared to. I went with a 4.250 eagle crank, I am curious to what your block to counterweight clearance was with your crank, and did the crank look like the counterweights had been cut? I only had .005-.020 clearance between the counterweights and the block mostly in the area where the main webs were bulged out and block had some humps in it. I clearanced it to .060, suggested by reading old build posts on this and other forums. It was a lot metal to remove with a burr and hard to get it all cut without leaving ridges, so I used a angle grinder with a really large 1/4 thick disc on it, and did plunge cuts on it until I get a piece of .060 wire to fit all around the counterweights when they were turned upward into the block. It turned out nice and smooth with a radius similar to the counterweights.. The rods and bolts cleared everything else with the 4.250 stroke.
Re: 541 stroker update. Stuffing it in there. [Re: Uberpube] #2928323
05/29/21 09:38 PM
05/29/21 09:38 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I didn't have any close calls with the crank and block. The rods hit the cam before timing was set.
- Stu Harmon
