Good low mount alternator kit for a 426 hemi motor #2923632
05/17/21 07:21 PM
05/17/21 07:21 PM
Cab_Burge Offline OP
I need a kit to mount a alternator on the driver side of a 426 hemi motor in a 1969 R.R. bracket car help Matching pulley needed also help
This car has a big aluminum cross flow radiator with the bottom hose fitting on the passenger side with a matching after market electric water pump shruggy
All help appreciated thumbs
Re: Good low mount alternator kit for a 426 hemi motor [Re: Cab_Burge] #2923637
05/17/21 07:27 PM
05/17/21 07:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Check with AndyF (AR Engineering) - he may have something.
Sound like it can't be mounted up high on the right, like the stock location ?
Re: Good low mount alternator kit for a 426 hemi motor [Re: topside] #2923641
05/17/21 07:32 PM
05/17/21 07:32 PM
no, the electric water pump and lower hose is in the way whiney
I call AndyF and left him a message, no reply yet if he offers a left side mounting kit or not. I hope he does, his stuff is engineer great and works well bow up
This car has a stock Hemi K member along with stock hemi motor mounts, if it had a front motor plate or elephant ears I would have had a lot easier time making a mount work for it shruggy
Re: Good low mount alternator kit for a 426 hemi motor [Re: Cab_Burge] #2923649
05/17/21 07:45 PM
05/17/21 07:45 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Jones Racing has the best one if you run a motor plate.
I believe they also have engine mounted ones as well.
Re: Good low mount alternator kit for a 426 hemi motor [Re: Sammy] #2923680
05/17/21 08:58 PM
05/17/21 08:58 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
doty mfg has them and they work good,but there hard to get
Re: Good low mount alternator kit for a 426 hemi motor [Re: dart games] #2923894
05/18/21 10:47 AM
05/18/21 10:47 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Best way to get a DMI bracket is right through them direct
Re: Good low mount alternator kit for a 426 hemi motor [Re: Cab_Burge] #2923899
05/18/21 10:56 AM
05/18/21 10:56 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
All the ones I've seen mount the Alt on the right.
I'm pretty sure the parts mentioned so far mount the Alt on the right as well.
(but you want/need it on the left).
Problem with low mounting it on the left like many GM products do it, is the oil pump and oil filter is in the way.
I think you will end up either fabricating something to work, or converting it to LH lower hose.
You could also high mount it on the right, it's not the most elegant solution as the Alt has to stick way out,
it's a little bit ugly but it can be made to function.
Rich H.
Esse Quam Videri
Re: Good low mount alternator kit for a 426 hemi motor [Re: Cab_Burge] #2923938
05/18/21 11:54 AM
05/18/21 11:54 AM
AndyF Offline
AndyF  Offline
I don't make anything to mount the alternator on the left side. There isn't much room on the left side since the oil pump is down low and the cylinder head is moved forward.
Re: Good low mount alternator kit for a 426 hemi motor [Re: AndyF] #2923988
05/18/21 02:28 PM
05/18/21 02:28 PM
The problem I'm having with this motor is the lower radiator hose feeding out of the water pump into the radiator on the passenger side and it having a after market electric water pump with the outlet on the passenger side. scope
Andy, does your low mount kit mount on the existing timing cover bolt location only or does it use some of the higher bolt holes in the heads?
Thanks!
Re: Good low mount alternator kit for a 426 hemi motor [Re: Cab_Burge] #2924199
05/19/21 01:12 AM
05/19/21 01:12 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi what are you using for an altinator < type and size > ?
looks like the owner just needs a new correct in / out rad and a correct water pump not the chevy ones he got at a swap meet .
a molded hose would look / work better also .
why are you adding an alt at this time ?
throw $500-600 at it and fix it correctly , its a hemi $$$
Re: Good low mount alternator kit for a 426 hemi motor [Re: calrobb2000] #2924266
05/19/21 09:45 AM
05/19/21 09:45 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have one of these
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Good low mount alternator kit for a 426 hemi motor [Re: bigdad] #2924281
05/19/21 10:38 AM
05/19/21 10:38 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: Good low mount alternator kit for a 426 hemi motor [Re: bigdad] #2924284
05/19/21 10:43 AM
05/19/21 10:43 AM
tboomer Online work
tboomer  Online Work
X2!!
Re: Good low mount alternator kit for a 426 hemi motor [Re: bigdad] #2924295
05/19/21 11:16 AM
05/19/21 11:16 AM
I called them on Monday and left a message, I called them again yesterday to ask about if they had a driver side kit and was told to call back on Thursday as the "office" was closed and the tech guy would be in on Thursday.
I'll call them again on Thursday and find out which alternators fits well with their kit, I hoping of a 100 amp or larger single wire luck
This picture really helps a bunch, THANKS up
Re: Good low mount alternator kit for a 426 hemi motor [Re: Cab_Burge] #2924356
05/19/21 12:26 PM
05/19/21 12:26 PM
ohio
blacksunshine Offline
ohio
Cab, I also had a stock location interference with my alternator. Here is a picture of my driver side arrangement. This is not an easy solution but if you like it, I'll help.
1969 Plymouth Satellite, A12+ tribute
+=426 Hemi EFI supercharged & intercooled
Re: Good low mount alternator kit for a 426 hemi motor [Re: Cab_Burge] #2924469
05/19/21 03:22 PM
05/19/21 03:22 PM
AndyF Offline
AndyF  Offline
Thanks!
That appears to be a bit of a hack job. Not even sure where to start. Guess it depends on what the customer wants and how much money they are willing to spend.
