Good low mount alternator kit for a 426 hemi motor
#2923632
05/17/21 07:21 PM
05/17/21 07:21 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I need a kit to mount a alternator on the driver side of a 426 hemi motor in a 1969 R.R. bracket car Matching pulley needed also This car has a big aluminum cross flow radiator with the bottom hose fitting on the passenger side with a matching after market electric water pump All help appreciated
Re: Good low mount alternator kit for a 426 hemi motor
[Re: topside]
#2923641
05/17/21 07:32 PM
05/17/21 07:32 PM
Cab_Burge
no, the electric water pump and lower hose is in the way I call AndyF and left him a message, no reply yet if he offers a left side mounting kit or not. I hope he does, his stuff is engineer great and works well This car has a stock Hemi K member along with stock hemi motor mounts, if it had a front motor plate or elephant ears I would have had a lot easier time making a mount work for it
[Re: dart games]
#2923894
05/18/21 10:47 AM
05/18/21 10:47 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Best way to get a DMI bracket is right through them direct
[Re: Cab_Burge]
#2923899
05/18/21 10:56 AM
05/18/21 10:56 AM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
All the ones I've seen mount the Alt on the right. I'm pretty sure the parts mentioned so far mount the Alt on the right as well.
(but you want/need it on the left).
Problem with low mounting it on the left like many GM products do it, is the oil pump and oil filter is in the way.
I think you will end up either fabricating something to work, or converting it to LH lower hose.
You could also high mount it on the right, it's not the most elegant solution as the Alt has to stick way out, it's a little bit ugly but it can be made to function.
Rich H.
Esse Quam Videri
[Re: AndyF]
#2923988
05/18/21 02:28 PM
05/18/21 02:28 PM
Cab_Burge
The problem I'm having with this motor is the lower radiator hose feeding out of the water pump into the radiator on the passenger side and it having a after market electric water pump with the outlet on the passenger side. Andy, does your low mount kit mount on the existing timing cover bolt location only or does it use some of the higher bolt holes in the heads? Thanks!
[Re: bigdad]
#2924295
05/19/21 11:16 AM
05/19/21 11:16 AM
Cab_Burge
I called them on Monday and left a message, I called them again yesterday to ask about if they had a driver side kit and was told to call back on Thursday as the "office" was closed and the tech guy would be in on Thursday. I'll call them again on Thursday and find out which alternators fits well with their kit, I hoping of a 100 amp or larger single wire This picture really helps a bunch, THANKS
[Re: Cab_Burge]
#2924356
05/19/21 12:26 PM
05/19/21 12:26 PM
Posts: 13 ohio
blacksunshine
ohio
Cab, I also had a stock location interference with my alternator. Here is a picture of my driver side arrangement. This is not an easy solution but if you like it, I'll help.
1969 Plymouth Satellite, A12+ tribute +=426 Hemi EFI supercharged & intercooled
[Re: Cab_Burge]
#2924469
05/19/21 03:22 PM
05/19/21 03:22 PM
Posts: 31,086 Oregon
AndyF
The problem I'm having with this motor is the lower radiator hose feeding out of the water pump into the radiator on the passenger side and it having a after market electric water pump with the outlet on the passenger side. Andy, does your low mount kit mount on the existing timing cover bolt location only or does it use some of the higher bolt holes in the heads? Thanks! That appears to be a bit of a hack job. Not even sure where to start. Guess it depends on what the customer wants and how much money they are willing to spend.
