Re: Dave Dudek [Re: Hemi_Joel] #2922660
05/15/21 12:17 AM
05/15/21 12:17 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Okay, if that won't work then melt an inconspicuous blob of material with a TIG welder on the air breather hold-down screws to keep the lid a half inch above the air filter to let more air in. The breather lid will ride slightly above the air filter and the wing nuts will tighten as normal.
You can just lift the lid to the point where it still appears to be covering the element, mark the position, and set your weld. twocents A second nut on the bottom of the breather will keep the bottom section still.
Mo' Farts
Moderated by "tbagger".
Re: Dave Dudek [Re: Grizzly] #2922671
05/15/21 12:55 AM
05/15/21 12:55 AM
I can remember the trick of the day that the Chevy street racers use to use on the streets in SO CA, they would turn the lid over so it let more air into the air cleaner body instead of having to suck all the air through the inlet tube shruggy
And Chevy engineers in 1966 use a open element with no air cleaner body around it on the 375 HP SS 396 Chevelle, not the 360 or 325 HP 396 shruggy
Re: Dave Dudek [Re: Cab_Burge] #2922935
05/15/21 07:29 PM
05/15/21 07:29 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Spray the air filter with nitromethane before a run , now it’s a power adder , lmao
....BAD A$$ STREET CAR.....
Re: Dave Dudek [Re: Hemi_Joel] #2923025
05/15/21 11:04 PM
05/15/21 11:04 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Originally Posted by Hemi_Joel
Originally Posted by MoonshineMattK
All of the restored cars I can find just have the screen. Funny enough found a corvette forum where they were discussing the 15 rear wheel horsepower that screen restricts. Wonder if that foam is a modification so people can drive them around. From what I understand L88 was considered a race only engine.
The reason that all you ever see is the screen is that the air filter is mounted in an air box in the hood. When you open the hood, it lifts the air filter up off of the engine, leaving the flame arrester screen on top of the carburetor.
Do you have a picture of how the filter is mounted inside the hood? I can't find one
Re: Dave Dudek [Re: MoonshineMattK] #2923030
05/15/21 11:17 PM
05/15/21 11:17 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I found this pic online
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Dave Dudek [Re: Hemi_Joel] #2923034
05/15/21 11:42 PM
05/15/21 11:42 PM
NW Illinois
NW Illinois
Thank you!
Wonder why they are being allowed to run without? Would have to make a huge difference
Re: Dave Dudek [Re: MoonshineMattK] #2923039
05/16/21 01:03 AM
05/16/21 01:03 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I talked to Donny, a FAST director on the phone today. He said the air filter was there during eliminations. I wasn't there, so I'll take him at his word.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Dave Dudek [Re: Hemi_Joel] #2923154
05/16/21 02:27 PM
05/16/21 02:27 PM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
I remember back in the day beating the Corvette,s with this 63 car because they were alway,s hooking up but they also broke the independent rear suspension and then one day NHRA decided they could run a straight axle [ imagine that] and so they put dana,s in and no more breakage !!! Then they went fast and won alot!!!
Re: Dave Dudek [Re: 72 RR DUDE] #2923548
05/17/21 03:58 PM
05/17/21 03:58 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
No straight axles there, I have seen the carnage.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Dave Dudek [Re: FurryStump] #2923563
05/17/21 04:31 PM
05/17/21 04:31 PM
NW Illinois
NW Illinois
I've never understood the allure of independent rear suspension. Unless driving off road I can't see the advantage
Re: Dave Dudek [Re: MoonshineMattK] #2923785
05/18/21 06:35 AM
05/18/21 06:35 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I believe it is better at most everything with the exception of Drag Racing.
68 Barracuda Formula S 340
Re: Dave Dudek [Re: Bad340fish] #2924008
05/18/21 03:16 PM
05/18/21 03:16 PM
NW Illinois
NW Illinois
Last year I drove 736 cars and trucks. From the drivers seat I'd be hard pressed to tell you if they were or were not independent rear suspension. What I can tell you is that independent rear suspension generates higher invoice totals wink
Re: Dave Dudek [Re: Hemi_Joel] #2925019
05/20/21 09:33 PM
05/20/21 09:33 PM
St Clair Shores, MI
DonnyBrass Offline
DonnyBrass  Offline
St Clair Shores, MI
Joel, thanks. I enjoyed chatting with you.
Bring your Hemi car out and I will get you a 1 race exemption from the air filter rule smile
Donny
Chevy infiltrator 12.34 @ 109.45 with a 1.73 sixty foot
Pure Stock
