Dave Dudek #2922215
05/13/21 07:40 PM
05/13/21 07:40 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
I saw he ran a 9.63@145 and change in his FAST 71 Hemi Cuda today. That's phenomenal, right out of the Twilight Zone!
Re: Dave Dudek [Re: quickd100] #2922225
05/13/21 08:11 PM
05/13/21 08:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
shock
Re: Dave Dudek [Re: justinp61] #2922249
05/13/21 09:27 PM
05/13/21 09:27 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Wait till tomorrow.....
Re: Dave Dudek [Re: John Brown] #2922258
05/13/21 09:49 PM
05/13/21 09:49 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That is phenomenal! Congrats to Dave. Long live Hemi power!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Dave Dudek [Re: John Brown] #2922259
05/13/21 09:51 PM
05/13/21 09:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Next time one of those L88 Corvettes run, somebody needs to look in the hood scoop and see if the air cleaner is actually there. It's required by the rules.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Dave Dudek [Re: Hemi_Joel] #2922261
05/13/21 10:01 PM
05/13/21 10:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Should still be good air tomorrow at 131.
Was around 1000 ft this afternoon when i looked, 800 this evening... will be super in the morning
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Dave Dudek [Re: Hemi_Joel] #2922321
05/14/21 06:39 AM
05/14/21 06:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
From what little I saw on facebook Dave had almost 5MPH on the corvette that went 9.58. The 60ft from that corvette was amazing though.
68 Barracuda Formula S 340
Re: Dave Dudek [Re: Bad340fish] #2922333
05/14/21 07:44 AM
05/14/21 07:44 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Yep, the air filter on an L-88 ain't on top of the carb, it's in the hood. Throws a lot of people for a loop.
Re: Dave Dudek [Re: John Brown] #2922334
05/14/21 07:47 AM
05/14/21 07:47 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
The Corvette that ran 9.58 isn't an L-88, but an L-68 (Tri-Power) combo.
Re: Dave Dudek [Re: sixpakdodge] #2922377
05/14/21 09:39 AM
05/14/21 09:39 AM
Cab_Burge Online work
Cab_Burge  Online Work
Is that the Lo Po 400 HP 427 or the 435 HP 427?
When you look at the 3rd. gen BB Corvette wheel base and were the driver sits in relation to the rear wheel it is easier to see why they do hook up so well scope
Hemi E body, not so much whiney scope
Re: Dave Dudek [Re: John Brown] #2922406
05/14/21 10:53 AM
05/14/21 10:53 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What throws me for a loop is when an L88 Corvette is awarded a record but yet no air cleaner was present on the carburetor or in the hood. I think the TriPower vet is a better choice for fast, simply because it has a bigger air cleaner element. Once you get the cars to this horsepower level, and you have to run through a stock appearing air cleaner, that's a big deal. Trying to make 800 horsepower through a tiny little air cleaner element is like running a marathon while breathing through a straw. Different cars have different advantages and disadvantages. That's the beauty of fast. There's no attempt by the rules makers to equalize the cars. A Corvette has some inherent advantages with weight distribution and aerodynamics, but the exhaust manifolds in the air cleaners aren't as good as a Hemi. It helps equalize things out and make them competitive without artificial interference like separating them into classes or handicaps.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Dave Dudek [Re: Hemi_Joel] #2922557
05/14/21 06:00 PM
05/14/21 06:00 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Joel, I was there at Martin today and ask about the air filter.
Their response was; "L-88's didn't come with an actual filter, just a wire screen, according to the factory assembly manual,"
Since I don't have an assembly manual (not gonna buy one either), evidently I was wrong earlier. I'll have to take their word for it.
Re: Dave Dudek [Re: John Brown] #2922558
05/14/21 06:05 PM
05/14/21 06:05 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
They only had the screen over the carb
Re: Dave Dudek [Re: John Brown] #2922562
05/14/21 06:15 PM
05/14/21 06:15 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Curious, had a tri carb vette, the filter was just a screen as you describe, but had an oiled foam "filter" similar to GM's HD air cleaner option. So, is the attached pic an actual L-88 air filter reproduction? It appears to be the same concept, a screen with an outer foam wrap.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Dave Dudek [Re: 3hundred] #2922564
05/14/21 06:23 PM
05/14/21 06:23 PM
NW Illinois
NW Illinois
All of the restored cars I can find just have the screen. Funny enough found a corvette forum where they were discussing the 15 rear wheel horsepower that screen restricts. Wonder if that foam is a modification so people can drive them around. From what I understand L88 was considered a race only engine.
Re: Dave Dudek [Re: MoonshineMattK] #2922587
05/14/21 07:52 PM
05/14/21 07:52 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I had talked to Dave about running a 1964 Aluminum Nose B Body in FAST years ago. I gave him some production number, how many car built, how many Hemi Block were cast in 1963 and 1964 and the three Hemi Head Casting numbers. FAST turned the 1964 Down because or production figures, but a Tupperware Corvette gets to compete. One reason I follow N Hemi Super Stock were you run what you own and it is a Hemi against a Hemi.
Keep running fast Dave we can all learn from your new ride, 1971 Hemi Cuda that looks better than most show cars.
1971 HEMI E BODY REGISTRY
Re: Dave Dudek [Re: hemicar1971] #2922597
05/14/21 08:21 PM
05/14/21 08:21 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
John, I think you know better than to take a Chevy driving FAST racer at his word! Of course they had a foam element around that screen. It's tiny and it kills power.
https://www.ecklerscorvette.com/1967-1969-corvette-air-cleaner-foam-element-l88-25-123937-1.html
https://corvetteparts.com/item/air-cleaner-assembly-427-with-l-88-engine-option-1967-1969
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Dave Dudek [Re: MoonshineMattK] #2922601
05/14/21 08:27 PM
05/14/21 08:27 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The reason that all you ever see is the screen is that the air filter is mounted in an air box in the hood. When you open the hood, it lifts the air filter up off of the engine, leaving the flame arrester screen on top of the carburetor.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Dave Dudek [Re: Hemi_Joel] #2922631
05/14/21 10:04 PM
05/14/21 10:04 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
You guys take everything else apart on the car and re-engineer it in F.A.S.T., what is stopping you from coming up with making your own air filter that has bonkers air flow and looks stock? Pull apart your Factory air filter, throw the paper out, find the coarsest white foam you can, cut it to look like weaved paper and stuff it in there. shruggy
Mo' Farts
Moderated by "tbagger".
Re: Dave Dudek [Re: Grizzly] #2922644
05/14/21 11:03 PM
05/14/21 11:03 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Rule: "3.06 The air filter housing assembly must appear correct. All qualifying and race runs must be done with the correct appearing air filter housing and an air filter in place. Correctly sized aftermarket air filters are OK." "Correct Appearing. Everything not specified otherwise must be correct appearing. “Correct appearing” and “appearing correct” means: upon a cursory visual inspection by someone reasonably familiar with the year, make and model claimed, it looks like a correct* part." "Correct* parts. These parts are the same as Correct* OEM parts, except they do not need to be OEM manufactured. Reproduction parts, that duplicate the Correct* Original parts in appearance, form, function and material and are primarily designed as “restoration” parts are allowed, as long as they comply with all other applicable rules."
Considering this, there is only so much you can do with the air filter and housing. And the Corvette is running illegal if the element is not in place.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
