What antifreeze to use these days in our old rides? #2922505
05/14/21 03:55 PM
05/14/21 03:55 PM
Kirkland, Washington
Pacnorthcuda Offline OP
1970 Cuda 440, aluminum heads, water pump, still has brass radiator. I always used Prestone green, but that’s not easy to find. What are you guys using in similar engines?
Re: What antifreeze to use these days in our old rides? [Re: Pacnorthcuda] #2922518
05/14/21 04:27 PM
05/14/21 04:27 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Yes, wonder why that is? flame
*Edit* Yeah, I know why that is: flame flame flame
Mo' Farts
Moderated by "tbagger".
Re: What antifreeze to use these days in our old rides? [Re: Grizzly] #2922525
05/14/21 04:31 PM
05/14/21 04:31 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I use quantum blue from BND auto with distilled water. Yes pricey
Facts are stubborn things.
Re: What antifreeze to use these days in our old rides? [Re: larrymopar360] #2922536
05/14/21 04:47 PM
05/14/21 04:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
None
Reverse osmosis water with Justice Brothers Coolant Protectant and JB Radiator Cooler
Edit: what are the lowest temp in Washington were your live. Is the car in garage? Attached or not?
Re: What antifreeze to use these days in our old rides? [Re: autoxcuda] #2922539
05/14/21 04:58 PM
05/14/21 04:58 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Zerex G-05
Aluminum Radiator/Heads
50/50 With Distilled Water
Gets a little chilly in WI even in the Spring and Fall believe it or not
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: What antifreeze to use these days in our old rides? [Re: bee1971] #2922548
05/14/21 05:25 PM
05/14/21 05:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Cheapest
Re: What antifreeze to use these days in our old rides? [Re: bee1971] #2922592
05/14/21 08:04 PM
05/14/21 08:04 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Aluminum heads, and intake. Some Red Premixed Caterpillar ELC safe for aluminum heads, water pumps etc. Had family that worked on Equipment who said it was not notch plus was free to me.
Used it in the 1994 Dodge 2500 diesel as well.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: What antifreeze to use these days in our old rides? [Re: Pacnorthcuda] #2922617
05/14/21 09:02 PM
05/14/21 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
napa should have it or did, I bought 6 or 7 cases of napa brand 50/50 long life about 3 months back
Re: What antifreeze to use these days in our old rides? [Re: Pacnorthcuda] #2922708
05/15/21 08:18 AM
05/15/21 08:18 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I just picked up 2 gallons of Prestone green concentrate the other day at my local autozone $13.99, they had premixed also at $15.99....$2 more for water and less AF, nice! But they were fully stocked with it, no Zerex though...
Re: What antifreeze to use these days in our old rides? [Re: bee1971] #2922772
05/15/21 11:01 AM
05/15/21 11:01 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Originally Posted by bee1971
Zerex G-05
This^^ Aluminum headed/aluminum rad 470"
Re: What antifreeze to use these days in our old rides? [Re: Pacnorthcuda] #2922780
05/15/21 11:17 AM
05/15/21 11:17 AM
AndyF Offline
AndyF  Offline
The brand doesn't matter. Use distilled water and small amount of anti-freeze and you'll be fine. Important thing is to change it on a regular basis. Once a year or at least once every two years. Don't let it sit in the car for years and years.
Re: What antifreeze to use these days in our old rides? [Re: AndyF] #2922800
05/15/21 12:15 PM
05/15/21 12:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Exactly
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What antifreeze to use these days in our old rides? [Re: BloFish] #2922805
05/15/21 12:36 PM
05/15/21 12:36 PM
central il.
second 70 Offline
second 70  Offline
central il.
Here's what ethylene glycol mixed with mineral water can do to aluminum after not being changed in 14 years in a car with only 2,000 that was all new. Only ate the tank nipple and only clogged the offset in the t and never leaked or over heated. The T was open straight to allow the coolant to flow fine. Battery was replaced after 10 years and it was fine. Lol
I should add that despite it looking perfectly green with 0 rust when drained it tested as having 0 protection.
Re: What antifreeze to use these days in our old rides? [Re: second 70] #2922815
05/15/21 01:07 PM
05/15/21 01:07 PM
moparx Offline
moparx  Offline
i have seen that green "mossy" stuff in old antifreeze, but Mopar Action's E-booger claims time and time again, that antifreeze doesn't wear out, it just needs water pump lubricant and something else [which i have forgotten] replenished every so often [which i have also forgotten the time frame].
so ? shruggy
beer
Re: What antifreeze to use these days in our old rides? [Re: moparx] #2923018
05/15/21 10:53 PM
05/15/21 10:53 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
I agree with Ehrenberg, the Man knows his stuff.
I have the original antifreeze (21 years old) in a 360 Magnum, and well over 30 to 40 years old in 440's, 340's, 318's and a Slant 6. Rads are all original and only have replaced the odd water pump.
Sorry if anyone else has different experiences, but I have had zero issues.
Mo' Farts
Re: What antifreeze to use these days in our old rides? [Re: Grizzly] #2923022
05/15/21 10:57 PM
05/15/21 10:57 PM
etheylene glycol doesn’t wear out, the additive package does,
Re: What antifreeze to use these days in our old rides? [Re: Grizzly] #2923109
05/16/21 10:49 AM
05/16/21 10:49 AM
central il.
second 70 Offline
second 70  Offline
central il.
I've had the same experience of it lasting forever but I was told this was caused by sitting and the aluminum. Antifreeze can become corrosive over the years. Shop calls it rot. Three things that helped cause it aluminum,cadmium plated steel T, and battery. You can see how clamp on tee by tank is rusted while the other clamp shows no damage.The red GM stuff will start taking out the water pump gasket after about 10 years. Won't hurt anything else. I've seem aluminum heads off diesel truck engines that had the yellow antifreeze in them and it looked like someone cut a groove in the head from water passage to cc. They said it's caused by the vibration of engine and causes it to separate and anyone whoever worked as a diesel mechanic knows better than to use it.
Re: What antifreeze to use these days in our old rides? [Re: second 70] #2923146
05/16/21 01:47 PM
05/16/21 01:47 PM
5thAve Offline
5thAve  Offline
I only use whatever I can find that's still actually green. Years ago Prestone started coming yellow instead of green and within months it would start filling my overflow bottle and other parts with goop. I think Peak is still green and the house brand from parts stores is usually geen too.
Re: What antifreeze to use these days in our old rides? [Re: 5thAve] #2923152
05/16/21 02:23 PM
05/16/21 02:23 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My 26 year old Jeep XJ just got a replacement radiator two years ago (leak).... my 20 year old pickup is still OE. Both maintained every 2-3 years (mopar green/distilled water).
My drag car (W8/iron block/aluminum rad) I store with a sacrificial anode and use the “pink” mopar 5yr ethylene glycol coolant.
Re: What antifreeze to use these days in our old rides? [Re: Pacnorthcuda] #2923174
05/16/21 03:52 PM
05/16/21 03:52 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Been running Evans since start up 3 years ago. Apparently others have complained of it being corrosive. I'm not noticing any corrosion whatsoever. Stuff is ridiculously expensive though. I'll never flush it. My radiator, heater core engine and hoses gulped down 7 gallons of that stuff at $40 a gallon.
I’m listening.
