Re: Does anyone have an OEM Hemi Booster Assembly?
[Re: DoctorDiff]
#2922354
05/14/21 08:45 AM
05/14/21 08:45 AM
Posts: 318 Iowa
ratroaster
Iowa
I'm looking for the overall width of the tubular fulcrum at the base of the linkage. This is basically the distance between the 2 side brackets. The big pin with the square head passes through it.
Right about 2.0" Cass.
[Re: ratroaster]
#2922510
05/14/21 04:05 PM
05/14/21 04:05 PM
Posts: 3,076 Michigan
A727Tflite
Right about 2.0" Cass. Is your pivot bolt able to be removed from the side brackets and such? If so I would greatly appreciate a picture of the unit disassembled. While the service manual shows an exploded view a picture would be more helpful. My pivot pin is seized, I need to get a new one made if I have to destroy it getting it apart.
[Re: A727Tflite]
#2922559
05/14/21 06:07 PM
05/14/21 06:07 PM
Posts: 318 Iowa
ratroaster
Iowa
Right about 2.0" Cass. Is your pivot bolt able to be removed from the side brackets and such? If so I would greatly appreciate a picture of the unit disassembled. While the service manual shows an exploded view a picture would be more helpful. My pivot pin is seized, I need to get a new one made if I have to destroy it getting it apart. Yah mine was seized also. Soaked in evaporust for a few days and still had to use a BFH to get it apart. I kind of screwed up the one end of the pivot that I have to rework yet. My pivot looks to be one solid unit, not individual spacers. etc
[Re: ratroaster]
#2922560
05/14/21 06:11 PM
05/14/21 06:11 PM
Posts: 318 Iowa
ratroaster
Iowa
One more...I don't really understand the reason they used the square headed pin. I guess its so the pin doesn't rotate and wear into the outer bracket holes.
[Re: ratroaster]
#2922581
05/14/21 07:24 PM
05/14/21 07:24 PM
A727Tflite
One more...I don't really understand the reason they used the square headed pin. I guess its so the pin doesn't rotate and wear into the outer bracket holes. That’s my understanding as well for the square headed bolt. My car sat for almost 40 years - the pin is seized in the pivot. I soaked my parts for a month to no avail. I even got it hot and used a press, so soap. Last trick I heard is to get it red hot then hit the pin/lever with candle wax. Sort of works like soldering plumbing, the wax gets sucked in. If that doesn’t work then I am going to use a vertical mill to drill out the square headed bolt.
[Re: DoctorDiff]
#2922736
05/15/21 09:55 AM
05/15/21 09:55 AM
Posts: 1,825 South Bend
John Brown
South Bend
I had 2 sets of original hemi booster linkage. I sold one a couple years ago and now I can only find one side bracket.
Both pins were seized. I heated the tubing red hot with a torch and drove the pin out with a punch.
Thanks for the dimensions. On seized parts like that, I heat them cherry red, then dip in water, or turn a hose on them if dipping isn't feasible. It's amazing how the abrupt temperature change loosens things. I do the same on exhaust manifolds with rusted/frozen studs. Haven't lost a manifold yet, and I even chance it on expensive ones too. Learned that trick from a blacksmith back in the early 60's. Would have sworn it couldn't work, but I was totally amazed.
[Re: fastmark]
#2922811
05/15/21 01:02 PM
05/15/21 01:02 PM
Posts: 19,406 north of coder
moparx
the candle wax trick really works ! i used this trick on the small screwdriver head cowl vent screen retaining screws of my 33 dodge humpback panel truck that were rusty, and also had half of the slot boogered up. after heating the screw red hot, and trying to not have the rust pop back and burn the head off, i applied a birthday cake candle to the screw[s]. not expecting anything, they screwed right out with little or no effort ! saved every single one of those tiny rascals ! if i remember right, they were 6-32 thread size. since then, i have used the candle trick on bolt threads up to 3/4-16, and have had success every single time !
