Sudden loss of oil pressure! #292087
04/18/09 07:27 PM
04/18/09 07:27 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Is there any reason for sudden loss of oil press?Before I shut the car off I had 45psi on the gauge at 2000rpm.I shut the car off,then restarted 10 min. later and nothing on the gauge.I disconnected the gauge at the block after checking the oil and fired it up,no oil coming out of the sender port.It's a 69 383 that's never been apart that I know of,any ideas?
Re: Sudden loss of oil pressure! [Re: Rosco] #292088
04/18/09 07:35 PM
04/18/09 07:35 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
I had the same thing happen with a 400, the oil pump failed 1 mile from my home. It was back in the day, so I just drove it home regardless, changed the pump and all was well. You could try another oil filter first.
Re: Sudden loss of oil pressure! [Re: Mopar1] #292089
04/18/09 07:38 PM
04/18/09 07:38 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Replace the pump and while there inspect the hex drive where it goes into the pump. Sometimes these round off.
Re: Sudden loss of oil pressure! [Re: Rosco] #292090
04/18/09 07:41 PM
04/18/09 07:41 PM
intermediate shaft
Re: Sudden loss of oil pressure! [Re: RapidRobert] #292091
04/18/09 07:55 PM
04/18/09 07:55 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Lifter popped out of it's bore, due to a bent push rod.
Pull the valve covers.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Sudden loss of oil pressure! [Re: hemi71x] #292092
04/18/09 08:12 PM
04/18/09 08:12 PM
MOORESVILLE NC
69four46 Offline
69four46  Offline
MOORESVILLE NC
Had the lifter thing happen to me too several times I would check that first.
Re: Sudden loss of oil pressure! [Re: 69four46] #292093
04/18/09 09:33 PM
04/18/09 09:33 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
FRAM filter collapsed. Happened to me will never use another.
Re: Sudden loss of oil pressure! [Re: 69four46] #292094
04/18/09 10:12 PM
04/18/09 10:12 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Yup
Free to check. Better than throwing parts at it.
Re: Sudden loss of oil pressure! [Re: dave571] #292095
04/18/09 10:43 PM
04/18/09 10:43 PM
!!!!!Lifter!!!!?!?!??! Are you telling me you shut the engine off NOT REALIZING that it was clanking and whanging (maybe) but missing badly on AT LEAST one cylinder????
I doubt this is a lifter. I'd check the filter/ oil pump/ drive.
Was the engine very hot?
What were you doing beforehand?
Re: Sudden loss of oil pressure! #292096
04/18/09 10:59 PM
04/18/09 10:59 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Just driving into town,about 65mph @2400rpm.Temp was normal.The engine sounds fine,no unusual noise.
Re: Sudden loss of oil pressure! [Re: Rosco] #292097
04/18/09 11:06 PM
04/18/09 11:06 PM
So what did you do?
Re: Sudden loss of oil pressure! #292098
04/18/09 11:17 PM
04/18/09 11:17 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
So what did you do?
I haven't done anything to it yet,except order a new pump&pan gasket.As good as it idled it's hard believe I bent a pushrod.
Re: Sudden loss of oil pressure! [Re: Rosco] #292099
04/19/09 08:59 AM
04/19/09 08:59 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well for any of us that have tossed lifters it's almost always on start up. From a bent pushrod but oil usually holds it in when under pressure. What happens is oils drains away and on start up they have a tendency to toss the lifter up and out!!
I had a cam that was terrible for bending pushrods back in the early eighties. I used to keep 3 or 4 in the trunk most often when you got gas or other start it up and 0 pressure. I'd pop the intake put lifter back in new push rod and go. later noticed the cam lobes were flaking took it back to mopar and they replaced it (I'm amazed too!!!) and never another bent pushrod.
Re: Sudden loss of oil pressure! #292100
04/19/09 09:27 AM
04/19/09 09:27 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I had a lifter pop out once on me too. Took the kid to the doc, came out to go home, no pressure. No clanking, no whanging, no missing. Only symptom was no oil pressure.
Replaced the pump, inspected the drive, etc, till I pulled valve cover and saw the culprit.
Don't be the exception.
Re: Sudden loss of oil pressure! [Re: Supercuda] #292101
04/19/09 09:37 AM
04/19/09 09:37 AM
Rosco we're waiting on you
Re: Sudden loss of oil pressure! [Re: Supercuda] #292102
04/20/09 09:57 AM
04/20/09 09:57 AM
dave571 Offline
dave571  Offline
yup.
It's a common problem, and isn't glaringly obvious as far as noise etc...
First hand experience for me here also...
Re: Sudden loss of oil pressure! [Re: dave571] #292103
04/20/09 09:30 PM
04/20/09 09:30 PM
shavertown pa.
K
kbeeper69 Offline
kbeeper69  Offline
K
shavertown pa.
same thing just happened to me,changed,oil pump,pan,fillter,pick-up,found 2 lifters out,3 pushrods out,also,no noises!! so what would cause this? last year only idled the car.
Re: Sudden loss of oil pressure! [Re: kbeeper69] #292104
04/27/09 09:55 PM
04/27/09 09:55 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
O.K.,I finally got back home to work on it.I pulled the Dist.&drive,put the primer shaft in the pump primed it and the pump works fine.I put everything back together took it for a drive,everything works fine,no noises,60psi press.all the power I had before.I'm using a supertech st8a filter,is that the problem or the oil pressure relief valve in the pump?
Re: Sudden loss of oil pressure! [Re: Rosco] #292105
04/27/09 11:09 PM
04/27/09 11:09 PM
the new pump took care of it?
Re: Sudden loss of oil pressure! [Re: RapidRobert] #292106
04/28/09 07:44 AM
04/28/09 07:44 AM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
I never installed the new oil pump.I'm wondering if I should still pull the valve covers and check pushrods though?
