Re: Sudden loss of oil pressure!
[Re: Mopar1]
#292089
04/18/09 07:38 PM
04/18/09 07:38 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
Replace the pump and while there inspect the hex drive where it goes into the pump. Sometimes these round off.
[Re: dave571]
#292095
04/18/09 10:43 PM
04/18/09 10:43 PM
!!!!!Lifter!!!!?!?!??! Are you telling me you shut the engine off NOT REALIZING that it was clanking and whanging (maybe) but missing badly on AT LEAST one cylinder????
I doubt this is a lifter. I'd check the filter/ oil pump/ drive.
Was the engine very hot?
What were you doing beforehand?
[Re: Rosco]
#292097
04/18/09 11:06 PM
04/18/09 11:06 PM
So what did you do?
#292098
04/18/09 11:17 PM
04/18/09 11:17 PM
Posts: 126 wi.
Rosco
wi.
So what did you do?
I haven't done anything to it yet,except order a new pump&pan gasket.As good as it idled it's hard believe I bent a pushrod.
[Re: Supercuda]
#292101
04/19/09 09:37 AM
04/19/09 09:37 AM
RapidRobert
Rosco we're waiting on you
[Re: Supercuda]
#292102
04/20/09 09:57 AM
04/20/09 09:57 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I had a lifter pop out once on me too. Took the kid to the doc, came out to go home, no pressure. No clanking, no whanging, no missing. Only symptom was no oil pressure.
Replaced the pump, inspected the drive, etc, till I pulled valve cover and saw the culprit.
yup.
It's a common problem, and isn't glaringly obvious as far as noise etc...
First hand experience for me here also...
