Are these used pistons any good? #2920783
05/10/21 02:59 PM
05/10/21 02:59 PM
Oklahoma City, Oklahoma
MrMayhem Offline OP
MrMayhem  Offline OP
I bought a set of Ross pistons from a FB seller that arrived a while back. I opened the box to find a few concerns that I would like more experienced builders to review. About 4 of the pistons show what appears to be light corrosion of the aluminum which can be felt if you drag your fingernail over the areas. It seems to clean up easy enough with a brillow pad but before I move any further with these I would like your input... here is a link to the part number of the pistons:
https://www.rosspistons.com/product...op-4-350-bore-3-750-stroke-3-50cc-82008/
Re: Are these used pistons any good? [Re: MrMayhem] #2920787
05/10/21 03:14 PM
05/10/21 03:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I would not run a piston that has been bead blasted, especially in the ring groves
Re: Are these used pistons any good? [Re: CSK] #2920788
05/10/21 03:16 PM
05/10/21 03:16 PM
MrMayhem Offline OP
MrMayhem  Offline OP
I dont think it has been bead blasted.... the surface is very smooth.
Re: Are these used pistons any good? [Re: MrMayhem] #2920838
05/10/21 05:03 PM
05/10/21 05:03 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Will the engine blow up because of it.... no.
Re: Are these used pistons any good? [Re: B1MAXX] #2920846
05/10/21 05:24 PM
05/10/21 05:24 PM
MrMayhem Offline OP
MrMayhem  Offline OP
If the pistons are usable for a hot street motor, what would be the best method to remove the corrosion or oxidation?
Re: Are these used pistons any good? [Re: MrMayhem] #2920853
05/10/21 05:30 PM
05/10/21 05:30 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Id send them goofy heavy things back to hot street 1978. I think youd do better even with a current set of hypers vs them. Corrosion/detonation? on that top.... meh.... beater dirt track all day long, id not spend the $200 balance money on those for street use.
Whats the compression height on those? Dont look setup for much of a cam or are they deep in the hole?
STOP POTATO HATE!
Re: Are these used pistons any good? [Re: Mr PotatoHead] #2920859
05/10/21 05:52 PM
05/10/21 05:52 PM
MrMayhem Offline OP
MrMayhem  Offline OP
Compression height of 2.067, supposed to produce 10:1 Compression with 84 cc head according to Ross Pistons. https://www.rosspistons.com/product...op-4-350-bore-3-750-stroke-3-50cc-82008/ Same part part number on the box.
Re: Are these used pistons any good? [Re: MrMayhem] #2920863
05/10/21 06:02 PM
05/10/21 06:02 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
That top look mighty porous. Ive had some that had minor signs of detonation I sent out and got the tops coated and never had a issue.
Them look like older pistons for some reason, maybe the dull finish.
Id be on the fence to use them as they are but opinions vary.
STOP POTATO HATE!
Re: Are these used pistons any good? [Re: Mr PotatoHead] #2920884
05/10/21 07:02 PM
05/10/21 07:02 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Ring groove clearance... measure ..... whatchoogot ?
Re: Are these used pistons any good? [Re: MrMayhem] #2920949
05/10/21 09:45 PM
05/10/21 09:45 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
a little scotchbrite and some wd
Re: Are these used pistons any good? [Re: MrMayhem] #2920961
05/10/21 10:03 PM
05/10/21 10:03 PM
Try contacting Chief Aircraft supplies in Oregon for some aluminum corrosion eater, if they are not open try another good aircraft repair parts store on the internet. Aircraft Spruce in SO CA is another good one scope
I owned and flew a small aircraft for 15 yrs in SO CA and used both of those companies for parts, Chief was cheaper due to Oregon not having any state sales tax even with the shipping up scope
I wish I could remember the brand name I used but the label fell off and I can't remember what I had for dinner Saturday night now whiney shruggy
