Are these used pistons any good?
#2920783
05/10/21 02:59 PM
05/10/21 02:59 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
I bought a set of Ross pistons from a FB seller that arrived a while back. I opened the box to find a few concerns that I would like more experienced builders to review. About 4 of the pistons show what appears to be light corrosion of the aluminum which can be felt if you drag your fingernail over the areas. It seems to clean up easy enough with a brillow pad but before I move any further with these I would like your input... here is a link to the part number of the pistons: https://www.rosspistons.com/product...op-4-350-bore-3-750-stroke-3-50cc-82008/
Re: Are these used pistons any good?
[Re: MrMayhem]
#2920787
05/10/21 03:14 PM
05/10/21 03:14 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I would not run a piston that has been bead blasted, especially in the ring groves
[Re: MrMayhem]
#2920853
05/10/21 05:30 PM
05/10/21 05:30 PM
Posts: 9,495 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Id send them goofy heavy things back to hot street 1978. I think youd do better even with a current set of hypers vs them. Corrosion/detonation? on that top.... meh.... beater dirt track all day long, id not spend the $200 balance money on those for street use.
Whats the compression height on those? Dont look setup for much of a cam or are they deep in the hole?
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2920859
05/10/21 05:52 PM
05/10/21 05:52 PM
MrMayhem
Compression height of 2.067, supposed to produce 10:1 Compression with 84 cc head according to Ross Pistons. https://www.rosspistons.com/product...op-4-350-bore-3-750-stroke-3-50cc-82008/ Same part part number on the box. Id send them goofy heavy things back to hot street 1978. I think youd do better even with a current set of hypers vs them. Corrosion/detonation? on that top.... meh.... beater dirt track all day long, id not spend the $200 balance money on those for street use.
[Re: MrMayhem]
#2920863
05/10/21 06:02 PM
05/10/21 06:02 PM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
That top look mighty porous. Ive had some that had minor signs of detonation I sent out and got the tops coated and never had a issue.
Them look like older pistons for some reason, maybe the dull finish.
Id be on the fence to use them as they are but opinions vary.
STOP POTATO HATE!
[Re: MrMayhem]
#2920949
05/10/21 09:45 PM
05/10/21 09:45 PM
Posts: 1,992 Apollo, PA.
B1MAXX
Apollo, PA.
If the pistons are usable for a hot street motor, what would be the best method to remove the corrosion or oxidation?
a little scotchbrite and some wd
