Re: Leaf spring slider question
[Re: poorboy]
#2929898
06/03/21 08:57 PM
06/03/21 08:57 PM
Posts: 4,672 Wichita
GY3
Wichita
The question is, do you really need them?
We've been 1.36 60 ft. with Cal-Tracs and a stock shackle with Poly bushings.
If I had a dedicated drag car or was going much faster I would consider them.
[Re: GY3]
#2929972
06/04/21 04:06 AM
06/04/21 04:06 AM
Posts: 234 Brisvegas, Australia
Alchemi
The question is, do you really need them? We've been 1.36 60 ft. with Cal-Tracs and a stock shackle with Poly bushings. If I had a dedicated drag car or was going much faster I would consider them. I would have thought having a free working spring would be great for any type of car? Do they detract from normal road handling in anyway?
[Re: Alchemi]
#2930028
06/04/21 11:25 AM
06/04/21 11:25 AM
GY3
Wichita
The question is, do you really need them? We've been 1.36 60 ft. with Cal-Tracs and a stock shackle with Poly bushings. If I had a dedicated drag car or was going much faster I would consider them. I would have thought having a free working spring would be great for any type of car? Do they detract from normal road handling in anyway? Not sure they detract but they are: 1. Extra expense 2. People have said they wear out quickly and make noise (no personal experience) 3. Require welding and fabrication to install and aren't a simple bolt in. They ARE lot of effort to install which, IMO, would yield minimal results in a street car.
[Re: justinp61]
#2930070
06/04/21 03:04 PM
06/04/21 03:04 PM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I just did a mini-tub and opted for shackles because of the noise. One thing you can do with shackles is use poly bushings which allow more movement than rubber.
Someone mentioned sliders being more work to install. I don't know how he figures that !! The sliders can be welded right to the inner rail and the car will still have stock ride height. Whereas to maintain stock ride height with shackles you have to drill the rail for the new shackle eye AND you have to notch the rail so the shackle has clearance during its travel.
[Re: Stanton]
#2930083
06/04/21 03:53 PM
06/04/21 03:53 PM
Posts: 2,859 Pattison Texas
CSK
Pattison Texas
I use nylon slides on my sliders, VERY quiet, they use them on 4x4 set ups
