727, Lazy 2-3 Shift #2919565
05/07/21 12:05 AM
05/07/21 12:05 AM
Oklahoma City, Oklahoma
MrMayhem Offline OP
MrMayhem  Offline OP
Hey all,
I have a mystery built BB 727 with a manual valve body.... (probably a modified valve body). The trans does not shift in Drive and does require manual input to shift. The 1-2 shift feels firm as it should but the 2-3 shift is super slow... It probably takes 1/2 a second to shift under hard acceleration with the shift being kinda soft. Before I invest much time and effort into this trans, can anyone give me a rough idea on what might be causing this issue?
Thank you
Re: 727, Lazy 2-3 Shift [Re: MrMayhem] #2919574
05/07/21 01:25 AM
05/07/21 01:25 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since the shift is soft in addition to being lazy, you might have a sealing problem at the front clutch; either worn sealing rings or hardened/shrunk lip seals. An air test is in order.
