damage from 2 step launch rev limiter? V.s pneumatic SLC #2918484
05/04/21 03:20 PM
05/04/21 03:20 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Does a 2 step launch control hurt the motor? Like matting the gas with no load (stick car) against the rev limiter? If so, what damage does it do?
How about these pneumatic starting line controllers? Anyone use one? Pros and cans of each? I can see that one preserves the accelerator pump shot, one wastes it. What else is there to consider?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Hemi_Joel] #2918490
05/04/21 03:29 PM
05/04/21 03:29 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
2 steps have been in use for 30 years or more. Even cars with trans brakes use them. No issues.
69 GTX 68 Road Runner
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: JERICOGTX] #2918495
05/04/21 03:33 PM
05/04/21 03:33 PM
Minnesota
Minnesota
All the ads for the starting line controllers say "Throw away that engine destroying 2-step!"
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Hemi_Joel] #2918500
05/04/21 03:51 PM
05/04/21 03:51 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Do you believe all ads?
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: JERICOGTX] #2918508
05/04/21 04:04 PM
05/04/21 04:04 PM
Minnesota
Minnesota
Well, you get about 50 passes per motor. How do you know it's not from the 2 step? My motor had weird damage on the valve tips. How do I know it's not from the 2 step?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Hemi_Joel] #2918511
05/04/21 04:12 PM
05/04/21 04:12 PM
an8sec70cuda Offline
I've heard that before too, but never seen any evidence of it. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Hemi_Joel] #2918519
05/04/21 04:23 PM
05/04/21 04:23 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
The first time I heard a two step was about 30 years ago. The only thought I had was all the banging cannot be good. I have used two steps on all of my race engines. They do not bang like the ones from many years past. They are extremely smooth. Maybe MSD changed the recipe from the originals.
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Hemi_Joel] #2918520
05/04/21 04:25 PM
05/04/21 04:25 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
Another thought, does the RPM's you are attempting to hold make a difference?
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: R3 Racing] #2918522
05/04/21 04:27 PM
05/04/21 04:27 PM
I recently changed my car from an MSD 6AL w/ a two step limiter to a digital 6AL-2. The rev limiter on the digital box definitely sounds smoother. Very different sound.
CHIP
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: an8sec70cuda] #2918525
05/04/21 04:32 PM
05/04/21 04:32 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have heard a 2 step beats the thrust bearing up. I have never seen any evidence of it on any of my junk.
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Hemi_Joel] #2918552
05/04/21 05:12 PM
05/04/21 05:12 PM
I wouldn't mat a stick shift car against the two step no matter the RPM on the starting line tsk twocents
Push the clutch in all the way and then use the throttle pedal to bring the RPM up against the two step is my choice work
I use to start dumping the clutch pedal at 5000 RPM and floor the gas pedal at the same time in my old NHRA stocker 1970 Hemi Cuda 4 speed car, shift at 7000 RPM years ago before the better clutches came out like available to day up That was way before two steps, circa 1973 shruggy
IHTHs
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Cab_Burge] #2918673
05/04/21 09:59 PM
05/04/21 09:59 PM
PA
moparacer Offline
moparacer  Offline
PA
The thing I liked about a SLC when I used one in Super Pro was the ability to mat the throttle at a dead idle and have the car hit the two step at the exact same time before the car launched every pass. Especially important with mechanical fuel injection.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Hemi_Joel] #2918731
05/05/21 06:14 AM
05/05/21 06:14 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Your issues, have more to do with the number of revolutions on the crankshaft, than it has to do with the 2 step.
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Cab_Burge] #2918732
05/05/21 06:19 AM
05/05/21 06:19 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
IHTHs
I'd be willing to bet every single Stock, and Super Stock car running a stick in the last 20 years, has parked the throttle right to the floor, on the 2 step, and it's never been a issue.
Now, if you are the type to go up on the 2 step the instant you stage, and the person in the other lane hasn't even lit the top bulb, then yeah, I could see an issue.
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: JERICOGTX] #2918764
05/05/21 09:14 AM
05/05/21 09:14 AM
Washington
madscientist Offline
Washington
IHTHs
^^^^^^^THIS^^^^^^^
The older 2 steps from say the mid 1980’s were hard on parts. Also depends on the brand. I’ve used older Mallory analog stuff and it did it sound like the MSD boxes.
The biggest issue I found was using mechanical injection and a 2 step. If you are at say...5000 RPM on the 2 step and your foot is on the floor the barrel valve is wide open. You are just hosing fuel into the chambers. I’ve seen bearing damage doing that.
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: madscientist] #2918852
05/05/21 12:20 PM
05/05/21 12:20 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I have seen no evidence that 2 steps hurt engines although I agree it sounds like it should...The functional difference between the 2 step and pneumatic limiters is mostly carb tuning. With the two step the carb is wide open so there are not any accl. pump concerns (ramp, size squitter vol. ). With pneumatic those are a concern. With a 2 step (or similar) I think you can mitigate your potential damage generation by how you use in I see quite often racers go in and get on the 2 step , some time even before the opponent has staged shruggy In my earlier days of racing and racing on a Full tree I preferred to Top bulb leave so I would release the TB on the top Bulb and and floor it on the second bulb. For those of you not using Delay boxes it becomes little tougher but manageable, Most recently I have tried and like leaving off the converter, no two step involved. better reaction time and very consistent.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: W.I.N. Racing] #2918884
05/05/21 02:03 PM
05/05/21 02:03 PM
my own world
theraif Offline
theraif  Offline
my own world
watching larry`s car makes you want to take a step back no
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: theraif] #2918901
05/05/21 02:47 PM
05/05/21 02:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Never seen that video my man Jeff actually spoke in camera, Im still in shock
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Al_Alguire] #2918923
05/05/21 03:44 PM
05/05/21 03:44 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
The turbo guys dump fuel and retard timing to ignite the fuel in the pipes and help spool the turbo. Seems to work but you better have your exhaust well built lol.
68 Barracuda Formula S 340
Re: damage from 2 step launch rev limiter? V.s pneumatic SLC [Re: Bad340fish] #2919004
05/05/21 07:04 PM
05/05/21 07:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Years ago I used both and I liked the throttle thingy better, it didn’t induce misfire. Both where only used at 3-3500 with a box but never pushed until the 2nd bulb.
