Power seat bolts in a junkyard car. #2918150
05/03/21 07:20 PM
05/03/21 07:20 PM
IMGTX Offline OP
IMGTX  Offline OP
Gonna pull some late model seats for my 74 Satellite.
Power seat is moved back over the bolts that hold it in and the junkyard won't allow you to take a battery in the yard.
I have spent long amounts of time surgically removing the seats from tracks and disassembling the track in the junkyard but I am not that into it this time.
I can get to the track motor connector. Anyone try a couple of 6V lantern batteries or possibly direct wiring a 18V drill battery to the drive motor?
Other ideas that work for you?
Re: Power seat bolts in a junkyard car. [Re: IMGTX] #2918155
05/03/21 07:28 PM
05/03/21 07:28 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
unbolt the motor maybe
Re: Power seat bolts in a junkyard car. [Re: IMGTX] #2918157
05/03/21 07:29 PM
05/03/21 07:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The small jump boxes will fit in your tool bag and they almost always allow them in anyway. It's what I use in this situation. I am referring to the ones that are slightly longer than your hand.
Master, again and still
Re: Power seat bolts in a junkyard car. [Re: DaveRS23] #2918158
05/03/21 07:31 PM
05/03/21 07:31 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Cant they get someone out there to help you?
China is the enemy.
Re: Power seat bolts in a junkyard car. [Re: 1972CudaV21] #2918191
05/03/21 08:54 PM
05/03/21 08:54 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
About the only junk yards around here these days are pull a part places. With those, you pay the entry fee, and have what ever tools you carried in, unless someone will lend you a tool you need. You are pretty much on your own getting your parts off and through the office to pay for them. The only help you get from the staff is what row the car your looking for is in, and what the part will cost you when your ready to leave.
Re: Power seat bolts in a junkyard car. [Re: poorboy] #2918192
05/03/21 08:57 PM
05/03/21 08:57 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
get one of the smaller ones from matco/napa or mac. they will hide real well. make sure you make/take some jumper wires with you.
Re: Power seat bolts in a junkyard car. [Re: trw1982] #2918220
05/03/21 09:48 PM
05/03/21 09:48 PM
Pa
K
koak Offline
koak  Offline
K
Pa
Jumper leads, 18v power tool battery. Motor will just run a bit quicker. I have also cranked cars in JY with jump box to do compression test before buying motors.
Re: Power seat bolts in a junkyard car. [Re: koak] #2918289
05/04/21 06:54 AM
05/04/21 06:54 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
What this guy said. Make some leads from the negative and pos on your battery and hook up to seat. Ive even seen one of those Milwaukee batteries' jump a dead car, they will power a seat easily if the motor is any good. Let us know!
Re: Power seat bolts in a junkyard car. [Re: moparjim79] #2918292
05/04/21 07:06 AM
05/04/21 07:06 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
when i disassemble salvage yard doors in the bodyshop. i use the battery from my cordless tools to power the windows up and down for access to the bolts.
the seat motor would easily be powered by those batteries with jumper wires.
i would suggest doing tests with your cordless batteries at home first to be sure you are jumping the batteries at the correct terminals to power things. trying to figure this out at the salvage yard could be a frustrating process.
perception is 90% of reality
Re: Power seat bolts in a junkyard car. [Re: IMGTX] #2918343
05/04/21 10:10 AM
05/04/21 10:10 AM
IMGTX Offline OP
IMGTX  Offline OP
Thank you for the advice.
Like somebody said about the only help you will get is where the car is. I would take the motor off but the bolts for the motor are under the seat and the drive ends are enclosed.
I don't use a jump box and hadn't realized how small they have gotten. Wow.
I have a dewalt drill that snapped the handle off. I think I will use the battery pack to power the seat. If that won't work I'll get a jump box.
It's raining for the next few days but I will let you know how it goes on Friday.
Thanks Again
Re: Power seat bolts in a junkyard car. [Re: IMGTX] #2920307
05/09/21 09:33 AM
05/09/21 09:33 AM
IMGTX Offline OP
IMGTX  Offline OP
I took a motor connector off another car and plugged it into a 20v drill battery. It moved the wrong way at first and I reversed the wires.
It worked like a charm.
I was skeptical about using a 20v battery on a 12v motor but it worked great and no damage.
Thanks again I am posting a picture for those curious in the future.
Re: Power seat bolts in a junkyard car. [Re: IMGTX] #2920338
05/09/21 11:13 AM
05/09/21 11:13 AM
A727Tflite Offline
A727Tflite  Offline
Nice tip!,
