rocker arm adj screws ? #2650386
04/29/19 10:20 PM
04/29/19 10:20 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
does any one make rocker arm screws 3/8 x 24 thd 5/16 ball 1.375 oal ?
i can find 1.5 long but need shorter, 1.375 or maby 1.250 oal .
thank you !
Re: rocker arm adj screws ? [Re: calrobb2000] #2650395
04/29/19 10:46 PM
04/29/19 10:46 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Did you try Manton and Smith Brothers?
2011 Drag Pak Challenger
Re: rocker arm adj screws ? [Re: rickseeman] #2917990
05/03/21 12:08 PM
05/03/21 12:08 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Smith Brothers makes 1.250" and 1.400" long adjusters in that config. About $100/set.
Re: rocker arm adj screws ? [Re: calrobb2000] #2917995
05/03/21 12:17 PM
05/03/21 12:17 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Originally Posted by calrobb2000
hi
thank you !
Just bought a set from Manton... $16 ea . they have three lengths, 1.250, 1.350,1.450 with and without a thru hole for added lube. See P/N's 823-02 or 824-02
Attached PDF document
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: rocker arm adj screws ? [Re: calrobb2000] #2917999
05/03/21 12:27 PM
05/03/21 12:27 PM
What type of lift and spring pressures makes a big difference in which quality and brand to buy, if race buy the good Manton scope
If not, buy the cheaper ones twocents
Re: rocker arm adj screws ? [Re: calrobb2000] #2918021
05/03/21 01:31 PM
05/03/21 01:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The greater the number of exposed threads when adjusted the higher the quality must be.
Boffin Emeritus
