Re: rocker arm adj screws ?
[Re: rickseeman]
#2917990
05/03/21 12:08 PM
05/03/21 12:08 PM
Posts: 9,096 Rogue River, OR
Jeremiah
Rogue River, OR
Smith Brothers makes 1.250" and 1.400" long adjusters in that config. About $100/set.
[Re: calrobb2000]
#2917995
05/03/21 12:17 PM
05/03/21 12:17 PM
Posts: 2,102 Byron, NY
W.I.N. Racing
Byron, NY
hi
does any one make rocker arm screws 3/8 x 24 thd 5/16 ball 1.375 oal ?
i can find 1.5 long but need shorter, 1.375 or maby 1.250 oal .
thank you ! Just bought a set from Manton... $16 ea . they have three lengths, 1.250, 1.350,1.450 with and without a thru hole for added lube. See P/N's 823-02 or 824-02
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: calrobb2000]
#2918021
05/03/21 01:31 PM
05/03/21 01:31 PM
Posts: 4,205 New York
polyspheric
New York
The greater the number of exposed threads when adjusted the higher the quality must be.
Boffin Emeritus
