First outing with new motor #2917970
05/03/21 11:30 AM
05/03/21 11:30 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Test and tuned Fri night
Went 10.77. Very healthy looking 6.78 at almost 101 in the 1/8. 1.44 60 foot
Car was missing badly all the way down the track. Got worse further down track i got. It was mineshaft air Fri night.
Then got hot over the weekend. Went from 800 feet to 4000 feet DA. Quite a swing..lol
Anyhow, either new wires, moving the rev limiter from 7k to 8k( wasnt going past 6500-6600 anyway) but you never know... and turned up fuel pressure 1/2 a pound to 7
Something fixed it, didn't have time to try one thing at a time on a race weekend
Anyhow, it did go 6.80 with a zero in much worse air.
Think this thing has at worst a low to mid 60 in the 1/4 next time i get it in good air. The above pass was literally right off the trailer with brand new mill.
Very happy for what it is. 565 gross lift flat tappet, heads peak at 272@550, eddies, weiand excellerator, and dinky 1 5/8 tube headers with muffs.
Had 7 or 8 gallons of fuel in the 15 gallon cell, weighed 3320 with my 322 behind the wheel on the US131 scales.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: First outing with new motor [Re: B3422W5] #2917981
05/03/21 11:54 AM
05/03/21 11:54 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Not a bad outing Don.
69 GTX 68 Road Runner
Re: First outing with new motor [Re: JERICOGTX] #2917985
05/03/21 12:00 PM
05/03/21 12:00 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Thanks Jeff. No, not bad at all. Got an issue with the pulley that bolts to the dampner that the alternator belt rides on..the bolts backing off.
Had to constantly keep checking them.
Put some lock washers on them, will see if it holds now. Never had an issue with that before
1.41 best 60 foot
6.60 at 103.90 1/8
Re: First outing with new motor [Re: B3422W5] #2917987
05/03/21 12:05 PM
05/03/21 12:05 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
If it was easy, everyone would be doing it. No doubt you will pick away at it, and it will go faster.
Re: First outing with new motor [Re: B3422W5] #2918002
05/03/21 12:30 PM
05/03/21 12:30 PM
New motor, new harmonics maybe work
Maybe time for some red locktight work up
Re: First outing with new motor [Re: B3422W5] #2918011
05/03/21 01:03 PM
05/03/21 01:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Keep after it Don, you'll get the kinks worked out. up
Re: First outing with new motor [Re: justinp61] #2918040
05/03/21 02:17 PM
05/03/21 02:17 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
That as good as a start as any !! Little fooling around.. your be flying !
Re: First outing with new motor [Re: VernMotor] #2918075
05/03/21 04:20 PM
05/03/21 04:20 PM
an8sec70cuda Offline
Good deal Don! Sounds like it's running strong!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: First outing with new motor [Re: B3422W5] #2918079
05/03/21 04:38 PM
05/03/21 04:38 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Very Nice, sounds like a great running streeter. A lil nitrous plate would really make you some $$$$ here and there.
....BAD A$$ STREET CAR.....
Re: First outing with new motor [Re: JERICOGTX] #2918084
05/03/21 04:45 PM
05/03/21 04:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Don.. its just lean.. jet it up... good start Don
wave
Re: First outing with new motor [Re: MR_P_BODY] #2918086
05/03/21 04:49 PM
05/03/21 04:49 PM
tboomer Offline
tboomer  Offline
Congrats Don!
Re: First outing with new motor [Re: MR_P_BODY] #2918089
05/03/21 04:54 PM
05/03/21 04:54 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
wave
I put 4 in the front and back, now its pig rich, but wasn't gonna mess with it bracket racing Saturday and Sunday. It was COLD Fri night. Plugs looked mighty lean..lol
1.41 best 60 foot
6.60 at 103.90 1/8
Re: First outing with new motor [Re: B3422W5] #2918112
05/03/21 05:53 PM
05/03/21 05:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
Yes it might show rich now but your gonna have to zero in on the jetting.. thats a a big swing on the temp and
when it warms up some you jet up some
Re: First outing with new motor [Re: MR_P_BODY] #2918139
05/03/21 06:54 PM
05/03/21 06:54 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Congratulations! boogie
Re: First outing with new motor [Re: B3422W5] #2918299
05/04/21 07:59 AM
05/04/21 07:59 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Congrats Don. Nice first outing. What size carb you runnin? What main jetting and what high speed bleeds?
Re: First outing with new motor [Re: B3422W5] #2918300
05/04/21 08:04 AM
05/04/21 08:04 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Congrats Don! Good runner!
Re: First outing with new motor [Re: HardcoreB] #2918305
05/04/21 08:14 AM
05/04/21 08:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Nice runs. I saw 28.6 barometer at Mid Michigan Sunday.
Doug
Re: First outing with new motor [Re: mopar dave] #2918342
05/04/21 10:09 AM
05/04/21 10:09 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Jets were 76/84 850 race brawler.
Swapped to 80/88jets... gonna change them back...
Hi speed 33/33
Idle 73/73
Was considering swapping the idles to around 60.. seem big to me.... doesn't idle real cleanly.... just off idle there is sometimes just a bit of a stumble/ hesitation. Dont see it when i footbrake it from 2k though. Just at tip in. So wanted to try going down some to richen it up a bit. Is my thinking correct?
1.41 best 60 foot
6.60 at 103.90 1/8
Re: First outing with new motor [Re: B3422W5] #2918542
05/04/21 05:03 PM
05/04/21 05:03 PM
[quote=mopar dave]
Fatten it up until it slows down in the 1/4 mile MPH, then lean it down carefully until it starts to slow down the MPH a little bit scope twocents
I ended up finding out that the pre pump fuel filter being to fine(80 microns or smaller) can make the fuel pump unable to supply enough fuel no matter what I did rant shruggy
Re: First outing with new motor [Re: B3422W5] #2918672
05/04/21 09:50 PM
05/04/21 09:50 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I ran 74/82 in my 850 on my 408. Our combos are different, so we take that into account. Dom told me when your jetting is close at wide open throttle you don’t have to get you hands wet doing jet changes. Just change HS bleeds and your golden. I tried this last time at track and it works. Wide band was reading 12.7 thru traps using 28HS bleeds in a Dominator. I switched to 32’s and then seen 13.3 on wide band . Car went quicker and faster mph. It works.
