First outing with new motor
#2917970
05/03/21 11:30 AM
05/03/21 11:30 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Test and tuned Fri night Went 10.77. Very healthy looking 6.78 at almost 101 in the 1/8. 1.44 60 foot Car was missing badly all the way down the track. Got worse further down track i got. It was mineshaft air Fri night. Then got hot over the weekend. Went from 800 feet to 4000 feet DA. Quite a swing..lol Anyhow, either new wires, moving the rev limiter from 7k to 8k( wasnt going past 6500-6600 anyway) but you never know... and turned up fuel pressure 1/2 a pound to 7 Something fixed it, didn't have time to try one thing at a time on a race weekend Anyhow, it did go 6.80 with a zero in much worse air. Think this thing has at worst a low to mid 60 in the 1/4 next time i get it in good air. The above pass was literally right off the trailer with brand new mill. Very happy for what it is. 565 gross lift flat tappet, heads peak at 272@550, eddies, weiand excellerator, and dinky 1 5/8 tube headers with muffs. Had 7 or 8 gallons of fuel in the 15 gallon cell, weighed 3320 with my 322 behind the wheel on the US131 scales.
Re: First outing with new motor
[Re: JERICOGTX]
#2917985
05/03/21 12:00 PM
05/03/21 12:00 PM
B3422W5
Portage,michigan
Thanks Jeff. No, not bad at all. Got an issue with the pulley that bolts to the dampner that the alternator belt rides on..the bolts backing off. Had to constantly keep checking them. Put some lock washers on them, will see if it holds now. Never had an issue with that before
[Re: B3422W5]
#2917987
05/03/21 12:05 PM
05/03/21 12:05 PM
Posts: 10,039 MN
JERICOGTX
MN
Thanks Jeff. No, not bad at all. Got an issue with the pulley that bolts to the dampner that the alternator belt rides on..the bolts backing off. Had to constantly keep checking them. Put some lock washers on them, will see if it holds now. Never had an issue with that before If it was easy, everyone would be doing it. No doubt you will pick away at it, and it will go faster.
69 GTX
68 Road Runner
[Re: B3422W5]
#2918002
05/03/21 12:30 PM
05/03/21 12:30 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
Thanks Jeff. No, not bad at all. Got an issue with the pulley that bolts to the dampner that the alternator belt rides on..the bolts backing off. Had to constantly keep checking them. Put some lock washers on them, will see if it holds now. Never had an issue with that before New motor, new harmonics maybe Maybe time for some red locktight
[Re: VernMotor]
#2918075
05/03/21 04:20 PM
05/03/21 04:20 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Good deal Don! Sounds like it's running strong!
[Re: B3422W5]
#2918079
05/03/21 04:38 PM
05/03/21 04:38 PM
Posts: 4,689 On the parachute mount
n20mstr
Very Nice, sounds like a great running streeter. A lil nitrous plate would really make you some $$$$ here and there.
....BAD A$$ STREET CAR.....
[Re: MR_P_BODY]
#2918089
05/03/21 04:54 PM
05/03/21 04:54 PM
B3422W5
Portage,michigan
Don.. its just lean.. jet it up... good start Don I put 4 in the front and back, now its pig rich, but wasn't gonna mess with it bracket racing Saturday and Sunday. It was COLD Fri night. Plugs looked mighty lean..lol
[Re: B3422W5]
#2918112
05/03/21 05:53 PM
05/03/21 05:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Don.. its just lean.. jet it up... good start Don I put 4 in the front and back, now its pig rich, but wasn't gonna mess with it bracket racing Saturday and Sunday. It was COLD Fri night. Plugs looked mighty lean..lol Yes it might show rich now but your gonna have to zero in on the jetting.. thats a a big swing on the temp and when it warms up some you jet up some
[Re: mopar dave]
#2918342
05/04/21 10:09 AM
05/04/21 10:09 AM
B3422W5
Portage,michigan
Congrats Don. Nice first outing. What size carb you runnin? What main jetting and what high speed bleeds? Jets were 76/84 850 race brawler. Swapped to 80/88jets... gonna change them back... Hi speed 33/33 Idle 73/73 Was considering swapping the idles to around 60.. seem big to me.... doesn't idle real cleanly.... just off idle there is sometimes just a bit of a stumble/ hesitation. Dont see it when i footbrake it from 2k though. Just at tip in. So wanted to try going down some to richen it up a bit. Is my thinking correct?
