Has anyone used Rare Parts for steering linkage items?
#2916756
04/29/21 10:05 PM
04/29/21 10:05 PM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
Looking at getting my original pitman arm rebuilt as it has the correct casting numbers on it and I believe it to be an original piece. I came across this place called Rare Parts ( www.rareparts.com) and it seems like they can make or rebuild any part for our cars since they have their own machining shop. Has anyone on here used them before? I remember that there were issues with the repros from Moog and other manufacturers that the angles were not right and the grease fittings were too high and hit the torsion bars causing other issues. thanks for the input.
inherited a 69 roadrunner from my grand pop.
Re: Has anyone used Rare Parts for steering linkage items?
[Re: fuelishnsilly]
#2917273
05/01/21 09:19 AM
05/01/21 09:19 AM
Posts: 10,703 North Dakota
6PakBee
North Dakota
I don't know if this helps or not. What I see in Rare Parts is:
1) they are lots of money 2) they are the only game in town for a lot of suspension/steering parts 3) what they make visually appears good
I bought some trunion bushings for my AMC SC/Rambler (don't ask) and they look good. I haven't gotten them installed so I can't tell you how well they work, but they look good.
[Re: fuelishnsilly]
#2917312
05/01/21 11:41 AM
05/01/21 11:41 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
I’m not familiar with them. Have you contacted them for a quote?
China is the enemy.
[Re: 1972CudaV21]
#2917410
05/01/21 03:36 PM
05/01/21 03:36 PM
Posts: 1,820 South Bend
John Brown
South Bend
All through the 70's and 80's, parts stores I worked for used RARE PARTS for oddball suspension parts. They were always quick and reliable, though sometimes a bit pricey. If our customer could stand the shock, we weren't afraid to use them.
[Re: 1972CudaV21]
#2918170
05/03/21 07:54 PM
05/03/21 07:54 PM
fuelishnsilly
Greenwood Lake, NY
Here is what I got back from them.
The pitman arm cost aprox. $175.00 + freight The idler arm cost aprox $145.00 + freight The build time once we received the parts can take 4-10 weeks depending on our work load
[Re: fuelishnsilly]
#2918274
05/04/21 04:38 AM
05/04/21 04:38 AM
1972CudaV21
Connecticut
The pitman arm cost aprox. $175.00 + freight The idler arm cost aprox $145.00 + freight The build time once we received the parts can take 4-10 weeks depending on our work load What are they starting with? Raw castings?
China is the enemy.
[Re: 1972CudaV21]
#2918617
05/04/21 07:58 PM
05/04/21 07:58 PM
fuelishnsilly
Greenwood Lake, NY
they have new castings but they can redo your original factory ones if you send them in to them. I remember there being an issue with the pitman arm or idler arm aftermarket design (don't know about their brand) being a different angle and having the grease fitting hitting the torsion bar on the pass side.
