A/C blows warm at stop UPDATE #2915344
04/26/21 05:36 PM
04/26/21 05:36 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I need some advice about my A/C in my truck.Blows cold all the time except when I stop at a light,It will blow warmAfter moving it starts getting cold again.Any advice how to fix this would be greatly appreciated.2005 Dodge Ram.
Re: A/C blows warm at stop [Re: 5carguy] #2915352
04/26/21 05:54 PM
04/26/21 05:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Sounds like the condenser fan is not working.
Re: A/C blows warm at stop [Re: 5carguy] #2915367
04/26/21 06:28 PM
04/26/21 06:28 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Do the 3rd gen Rams have blend door issues like the 2nd gen Rams? My 2nd gen Ram did that, except I could hear the blend door "slam" shut when I came to a stop, then suddenly nothing but heat.
Re: A/C blows warm at stop [Re: 5carguy] #2915369
04/26/21 06:31 PM
04/26/21 06:31 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
nN is spot on but HOW THE FUGG would he know ?? ! From a guy who has to use his heater IN JULY in YOOPER Michigan by the North Pole! grin
And YOU ... 2 1/2 guy ... needing AC in Lee county ? ... don’t you get enuff cool breezes OFF THE Everglades tsk grin
Re: A/C blows warm at stop [Re: 5carguy] #2915381
04/26/21 06:55 PM
04/26/21 06:55 PM
USA
rftroy Offline
rftroy  Offline
USA
Check your charging system, and current flow to the compressor clutch at idle.
if you have issues with your charging system, and current gets too low at idle, there may not be enough current to hold the clutch engaged.
Rather than becoming completely disconnected, it could be slipping, which will burn up the clutch very quickly.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: A/C blows warm at stop [Re: 5carguy] #2915389
04/26/21 07:05 PM
04/26/21 07:05 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Is it just the passenger side? Or both sides?
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: A/C blows warm at stop [Re: Prodart440] #2915393
04/26/21 07:13 PM
04/26/21 07:13 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Yes, fan issue. I'm betting if you added an electrical fan you'd notice a difference, but thats not fixing the problem.
Re: A/C blows warm at stop [Re: 5carguy] #2915394
04/26/21 07:17 PM
04/26/21 07:17 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
thought about cking pressures
Low on Freon will do that.
cooling fan not working will as well
Re: A/C blows warm at stop [Re: moparjim79] #2915448
04/26/21 09:08 PM
04/26/21 09:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The condenser already has an electric fan on these models. The poster has to see if it runs. My bets the fan is inoperative.
Re: A/C blows warm at stop [Re: NITROUSN] #2915524
04/27/21 06:54 AM
04/27/21 06:54 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Ah! My mistake with what I thought was 95
Re: A/C blows warm at stop [Re: moparjim79] #2915530
04/27/21 07:29 AM
04/27/21 07:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If the fan is working it is very possible there is debris between the condenser and radiator. Grass clippings, plant seed fuzzys etc. The condition is generally caused by lack of air flow thru the condenser.
Doug
Re: A/C blows warm at stop [Re: dvw] #2915565
04/27/21 09:27 AM
04/27/21 09:27 AM
central il.
second 70 Offline
second 70  Offline
central il.
Might check and make sure the clutch on the compressor isn't turning off at idle and then coming back on with rpms.
Re: A/C blows warm at stop [Re: NITROUSN] #2915594
04/27/21 10:34 AM
04/27/21 10:34 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
If it is a gas model, yes it has a fan. If a diesel it does not.
Aaron
68 Coronet 440
Re: A/C blows warm at stop [Re: Prodart440] #2915687
04/27/21 01:24 PM
04/27/21 01:24 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It is the condenser fan. I've replaced two of them in my 2007 Ram 1500. The fan motors wear out and at low vehicle speeds, the A/C blows hot..
Re: A/C blows warm at stop [Re: Kern Dog] #2915762
04/27/21 04:03 PM
04/27/21 04:03 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Thanks for the replies.Problem solved.It was the condenser cooling fan.Changed fan motor and all is well.Thanks again for the great advice.
Re: A/C blows warm at stop [Re: 5carguy] #2915765
04/27/21 04:08 PM
04/27/21 04:08 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Of course I was right.
Re: A/C blows warm at stop [Re: Kern Dog] #2915806
04/27/21 05:29 PM
04/27/21 05:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I was first. So I am righter.
Re: A/C blows warm at stop [Re: NITROUSN] #2915884
04/27/21 08:51 PM
04/27/21 08:51 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Yep...You are bester.
Re: A/C blows warm at stop [Re: Kern Dog] #2915903
04/27/21 09:38 PM
04/27/21 09:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Not according to my Wife.
Re: A/C blows warm at stop [Re: Kern Dog] #2915954
04/28/21 12:56 AM
04/28/21 12:56 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
FYI, you're beginning to sound like Doc.
up to OP. Glad you got it figured out!
