A/C blows warm at stop UPDATE
#2915344
04/26/21 05:36 PM
04/26/21 05:36 PM
Posts: 2,404 Lee Co. Fla.
5carguy
Lee Co. Fla.
I need some advice about my A/C in my truck.Blows cold all the time except when I stop at a light,It will blow warmAfter moving it starts getting cold again.Any advice how to fix this would be greatly appreciated.2005 Dodge Ram.
Re: A/C blows warm at stop
[Re: 5carguy]
#2915381
04/26/21 06:55 PM
04/26/21 06:55 PM
Posts: 704 USA
rftroy
USA
Check your charging system, and current flow to the compressor clutch at idle. if you have issues with your charging system, and current gets too low at idle, there may not be enough current to hold the clutch engaged. Rather than becoming completely disconnected, it could be slipping, which will burn up the clutch very quickly.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: 5carguy]
#2915389
04/26/21 07:05 PM
04/26/21 07:05 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
I need some advice about my A/C in my truck.Blows cold all the time except when I stop at a light,It will blow warmAfter moving it starts getting cold again.Any advice how to fix this would be greatly appreciated.2005 Dodge Ram. Is it just the passenger side? Or both sides?
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: moparjim79]
#2915448
04/26/21 09:08 PM
04/26/21 09:08 PM
Posts: 18,415 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Yes, fan issue. I'm betting if you added an electrical fan you'd notice a difference, but thats not fixing the problem. The condenser already has an electric fan on these models. The poster has to see if it runs. My bets the fan is inoperative.
[Re: NITROUSN]
#2915524
04/27/21 06:54 AM
04/27/21 06:54 AM
Posts: 1,405 Central Pa
moparjim79
Central Pa
Yes, fan issue. I'm betting if you added an electrical fan you'd notice a difference, but thats not fixing the problem. The condenser already has an electric fan on these models. The poster has to see if it runs. My bets the fan is inoperative. Ah! My mistake with what I thought was 95
[Re: NITROUSN]
#2915594
04/27/21 10:34 AM
04/27/21 10:34 AM
Prodart440
Avondale AZ
Yes, fan issue. I'm betting if you added an electrical fan you'd notice a difference, but thats not fixing the problem. The condenser already has an electric fan on these models. The poster has to see if it runs. My bets the fan is inoperative. If it is a gas model, yes it has a fan. If a diesel it does not.
Aaron
