Power steering pump shaft play #2912410
04/20/21 04:24 PM
04/20/21 04:24 PM
Kingston, Ontario
70GranCoupe Offline OP
Kingston, Ontario
I have a clacking noise coming from the Federal power steering pump when the car is running. I have pulled the pump and found that there is about a 1/4 inch of play on the shaft when I pull the pulley away from the pump body. Is this normal or should there be less play. Thanks.
Re: Power steering pump shaft play [Re: 70GranCoupe] #2915518
04/27/21 05:27 AM
04/27/21 05:27 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
I just rebuilt my federal pump last week to correct a leak. It has the same amount of play in and out but doesn't make noise when running. I checked a different pump and it had the same movement. I'd say it's normal
Re: Power steering pump shaft play [Re: solarguy] #2915742
04/27/21 03:10 PM
04/27/21 03:10 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
both mine are the same
