Dana ID (power lock or trak lock?) #291397
04/17/09 09:40 PM
04/17/09 09:40 PM
BDW Offline OP
BDW  Offline OP
I have this center section, how can I tell if it is a power lock or a track lock? I think it came out of a 70 e-body.
Thx
Re: Dana ID (power lock or trak lock?) [Re: BDW] #291398
04/17/09 09:59 PM
04/17/09 09:59 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Comparison
Re: Dana ID (power lock or trak lock?) [Re: Snoopy] #291399
04/17/09 10:21 PM
04/17/09 10:21 PM
Florence, Alabama
72440dart Offline
72440dart  Offline
Florence, Alabama
just ordered clutches for my trac-lok, tech guy at dts told me if it had 8 bolts holding the two cases together it was a pwr. lock, if it just had a center pin and a roll pin holding it then it was a trac lok.
Corey
Re: Dana ID (power lock or trak lock?) [Re: BDW] #291400
04/17/09 10:35 PM
04/17/09 10:35 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
That`s a power lock in your picture.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Dana ID (power lock or trak lock?) [Re: 72440dart] #291401
04/17/09 10:35 PM
04/17/09 10:35 PM
BDW Offline OP
BDW  Offline OP
Corey
Are these the bolts that can be seen in my pic? It looks like there is maybe 14-16 of these?
Thx
Re: Dana ID (power lock or trak lock?) [Re: BDW] #291402
04/17/09 10:42 PM
04/17/09 10:42 PM
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
There`s bolts on the other end that can`t be seen in your picture. They hold the case halves together. The big bolts in your picture hold the ring gear on.
Re: Dana ID (power lock or trak lock?) [Re: gamagoat6x6] #291403
04/17/09 10:45 PM
04/17/09 10:45 PM
BDW Offline OP
BDW  Offline OP
Thx for the help,
Which version is considered the best?
Re: Dana ID (power lock or trak lock?) [Re: BDW] #291404
04/17/09 11:32 PM
04/17/09 11:32 PM
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Your power lock has four spider gears instead of the track locks` two so it`s stronger and an overall better design. They`re expensive to produce so like most everything else that was good they quit using them in everything but the heavier trucks that still needed a good axle.
Re: Dana ID (power lock or trak lock?) [Re: BDW] #291405
04/18/09 06:33 AM
04/18/09 06:33 AM
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Before you spend time and money installing that, check the axle spline count. It could be a 30 spline truck unit.
Re: Dana ID (power lock or trak lock?) [Re: gamagoat6x6] #291406
04/18/09 07:49 AM
04/18/09 07:49 AM
BDW Offline OP
BDW  Offline OP
I'll check.
Thx for the help.
