Serpentine belt life ? #2913666
04/22/21 09:59 PM
04/22/21 09:59 PM
Florida STAYcation
BeEtLeJuIcE ! Offline OP
The village idiot's idiot
Florida STAYcation
A certain INfamous - and many time BANNED - Cereal Guy recently claimed over 350k miles on an original belt !
NOT questioning that .. I’ve seen very little wear on lotsa belts ...
You ?
Re: Serpentine belt life ? [Re: BeEtLeJuIcE !] #2913677
04/22/21 10:19 PM
04/22/21 10:19 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Ha ha....
356,000 miles on my truck...original belt!
Re: Serpentine belt life ? [Re: Kern Dog] #2913683
04/22/21 10:32 PM
04/22/21 10:32 PM
Florida STAYcation
Florida STAYcation
FrankenBerri... wasssupy ?
So what do YOU attribute the long life you ?
Thin construction... thus cooler running ? Inside ribbing ?
Re: Serpentine belt life ? [Re: BeEtLeJuIcE !] #2913690
04/22/21 10:45 PM
04/22/21 10:45 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Ive got 11 years on one, plan to change it just because im gonna do a bit of other work.
How about 155k on org. plugs and front rotors???? Thats my current best.
I wonder if franken wore out several idlers in that 350k?
STOP POTATO HATE!
Re: Serpentine belt life ? [Re: BeEtLeJuIcE !] #2913694
04/22/21 10:51 PM
04/22/21 10:51 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Yeah, I don't know. My truck (2001, Ram, 1500, 5.2) probably had 100,000+ on it before I had to change a belt. I've tried several belts (that ALL sucked), and found an AC Delco (of all brands) that has lasted a few years. However, it seems it's time a gain. Belt is beginning to squeal for a minute or so if the truck sits for more than 12ish hours.
Re: Serpentine belt life ? [Re: Mr PotatoHead] #2913695
04/22/21 10:53 PM
04/22/21 10:53 PM
Florida STAYcation
Florida STAYcation
I’ll bet berri GREASED THEM !
Re: Serpentine belt life ? [Re: Fat_Mike] #2913696
04/22/21 10:55 PM
04/22/21 10:55 PM
Florida STAYcation
Florida STAYcation
AM fm .. ever try Gates ?
Re: Serpentine belt life ? [Re: BeEtLeJuIcE !] #2913697
04/22/21 10:56 PM
04/22/21 10:56 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
The serpentine belt on my cummins has 450,000 kms on it, it's a gates.
Re: Serpentine belt life ? [Re: Uberpube] #2913698
04/22/21 11:05 PM
04/22/21 11:05 PM
Florida STAYcation
Florida STAYcation
uP .. 450 Canadian? .. isn’t that about A MILLION ... USA? xmaseek
Re: Serpentine belt life ? [Re: BeEtLeJuIcE !] #2913736
04/23/21 01:36 AM
04/23/21 01:36 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
My water pump drips sometimes so when I dig in to replace it, I'll change the belt at that time.
I have no clue why this one lasted this long. It still looks good, though the black has faded to a gray color. No cracks though. It gets hot here.....
Re: Serpentine belt life ? [Re: Kern Dog] #2913737
04/23/21 02:05 AM
04/23/21 02:05 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
My 96 powerstroke still has the org. belt, thats alot of years but still low low miles and is parked indoors 24/7.
STOP POTATO HATE!
Re: Serpentine belt life ? [Re: Mr PotatoHead] #2913750
04/23/21 07:21 AM
04/23/21 07:21 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
20 years and 221000 on the ford focus when I sold it
Re: Serpentine belt life ? [Re: 58pwrwgn] #2914547
04/24/21 11:42 PM
04/24/21 11:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The serpentine belts do tend to last a long time. I think its because the ribs running on most of the pulleys add a lot more grip then the one single groove of a V belt, so the flat belt doesn't as allow much slipping like the V belt design. does. The less slipping, the less heat, and the longer life span. I think the reason most people change the serpentine belt is because of the cracks they see between the cogs across the belts. Most damaged serpentine belts I've seen were split along its length when the belt got off the sides of the pulleys. Gene
Re: Serpentine belt life ? [Re: BeEtLeJuIcE !] #2914553
04/24/21 11:58 PM
04/24/21 11:58 PM
N.W. Florida
N.W. Florida
Yep, Gates from O'Reilly. Not sure which grade, so some may be better than others. The AC Delco has a "lifetime warranty." It lasted longer than expected, but I'm all ears for a better one.
