Re: Spectra Premium Gas Tanks?
[Re: RJS]
#2913743
04/23/21 03:39 AM
04/23/21 03:39 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I was searching the net for the best deal on a Spectra Premium tank CR 14 and it came up as AMD is that who took them over?
Then I find another company TRQ that I've never heard of, I like to buy the Spectra because they were always natural galvanized but I see a bunch of tanks that have that grey painted look.
Any advice out there? Thanks Ron Not galvanized, meaning not hot dipped in zinc. They are Ni-Terne coated, according to the Spectra Premium website. During the muscle car era and before, terne was an alloy of 80-90% lead and 10-20% tin. Later the lead was replaced with zinc. Today terne plate is mostly tin, but apparently Spectra uses terne sheet with a nickel addition to the coating. (Wikipedia)
[Re: kentj340]
#2913796
04/23/21 10:12 AM
04/23/21 10:12 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Any advice out there? Thanks Ron Not galvanized, meaning not hot dipped in zinc. They are Ni-Terne coated, according to the Spectra Premium website. During the muscle car era and before, terne was an alloy of 80-90% lead and 10-20% tin. Later the lead was replaced with zinc. Today terne plate is mostly tin, but apparently Spectra uses terne sheet with a nickel addition to the coating. (Wikipedia) So is the AMD the same as a Spectra Premium or different process? Thanks Ron
