Three prong flasher #2913287
04/22/21 07:52 AM
04/22/21 07:52 AM
Georgia
72440CUDA Offline OP
Georgia
Something I never really gave much thought because I’ve never had to replace it, but, is the three prong turn signal flasher on my ‘Cuda some sort of unicorn? 😂
I can’t seem to find anything that matches up, just the universal style. If I have to, I’ll make some jumper wires to connect a standard flasher to the original harness, but would rather not.
I switched over to LED bulbs and the LED flasher I received is a two prong. It worked for my hazard flasher but I need one to work for my three prong turn signal flasher 🙃
Re: Three prong flasher [Re: 72440CUDA] #2913290
04/22/21 07:59 AM
04/22/21 07:59 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
looks like a time delay relay 2889565 https://www.ebay.com/p/1722241373
Re: Three prong flasher [Re: mopars4ever] #2913307
04/22/21 09:02 AM
04/22/21 09:02 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Agree with mopars4ever. The time delay relay turns the ignition key light on/off. It is not the turn signal flasher relay.
Re: Three prong flasher [Re: mrob] #2913309
04/22/21 09:13 AM
04/22/21 09:13 AM
Georgia
Georgia
Ok thanks, I’ll continue to dig to figure out why turn signals won’t cycle, but the hazards do.
Re: Three prong flasher [Re: 72440CUDA] #2913313
04/22/21 09:31 AM
04/22/21 09:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally flashers are activated by bulb loads. they are allways energized, but untill bulbs are not sucking load the flasher won't be activated. I guess getting the led conversion, you got the electronic flasher for it, but STILL the signal should be there for them just like originals did
Of course hazzards are feeded from BATT source, while turning needs to get the ign key in ACC or RUN.
Assuming by your screen name you are working on a 72, you can check the red wire arriving to turning switch plug down the column. Put your ign swith on ACC and check for power on turning switch plug. It must be energized. If not, you have a damaged flasher or even unexistant one.
If you have power and still don't get turnings working, it could be the switch damaged... or bulbs
P.S.: the 3 ways flasher there as mentioned is for the ign switch courtesy light on column just at a side of the hazzard knob. It will turn on that light for around 8-15 seconds after get the dome light on and off ( doors opened or dimmer dome light on )
Re: Three prong flasher [Re: NachoRT74] #2913320
04/22/21 09:47 AM
04/22/21 09:47 AM
BDW Online content
BDW  Online Content
Re: Three prong flasher [Re: BDW] #2913335
04/22/21 10:29 AM
04/22/21 10:29 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Jumping the red wire to the white wire into the column switch will make blink both rears with turning switch in rest position. That will discard the flasher of course, but not the turning switch completelly. On rest position turning switch gets rear lights linked to the white wire which is the normally closed position for the brake lights coming from pedal switch
then as mentioned on article, feeding each corner ( both greens, tan and brown ) and get the lights work but not through the switch which will confirm switch is bad.
Re: Three prong flasher [Re: 72440CUDA] #2913368
04/22/21 11:34 AM
04/22/21 11:34 AM
IMGTX Offline
IMGTX  Offline
There are two flashers on some of my old mopars, one for hazards and one for turn signal.
One above the brake pedal and one on the side of the ashtray in the center of the dash.
Can't remember which cars specifically. It's been awhile since I had to replace one, so I don't remember which is which.
Did you replace both?
Not uncommon for one to be round and other to be square.
Re: Three prong flasher [Re: IMGTX] #2913466
04/22/21 02:55 PM
04/22/21 02:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the brake pedal one uses to be hazzard and USED to be the heavy duty squared version. It can be replaced by any round piece as far is heavy duty ( for 6 bulbs ). Tipically labeled with a green band
the one around ashtray it uses to be the turning signal, regular round flasher
Re: Three prong flasher [Re: NachoRT74] #2913631
04/22/21 08:35 PM
04/22/21 08:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, two flasher units. The easy one to find is always the hazard flasher and it seldom gives you any problems. For some reason, Chrysler thought it would be fun to hide the turn flasher that goes bad. Generally the turn flasher is connected to a connecter that is separate from everything else. Often they are found hanging under the dash by the wires, near the radio & ash tray.
It wasn't until the mid 80s Chrysler decided to put the turn signal flasher on the fuse box along with the hazard flasher unit. Gene
Re: Three prong flasher [Re: poorboy] #2913658
04/22/21 09:37 PM
04/22/21 09:37 PM
Georgia
Georgia
Update:
Thanks everyone! The turn signal flasher was hidden between the ash try and glove box. No idea why Chrysler decided to do that as it was said above.
I have now replaced the hazard and turn signal flashers with LED compatible ones (had to use the polarity reversing adapter) and everything works!!
This will get me by until I can install my American Autowire update harness
Thanks again!
07BD1E5B-258E-4CF7-80ED-0568D950A3CA.jpeg781CF1C7-54FC-4804-8B96-BD46AFA3E170.jpeg8CE1D976-ECD0-4270-AE1D-9D08F791C163.jpeg3F06A486-B632-4006-9C86-D54E75D4E717.jpeg
Re: Three prong flasher [Re: 72440CUDA] #2913935
04/23/21 02:13 PM
04/23/21 02:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeap, the turning signal flasher uses to be hold by this bracket
which is attached to the ashtray housing like this ( note the right bottom corner)
Re: Three prong flasher [Re: NachoRT74] #2914543
04/24/21 11:21 PM
04/24/21 11:21 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Interesting! I don't believe I ever saw a turn flasher that wasn't just hanging from the wires! I couldn't imaging Mopar doing that, but after seeing the attaching bracket was for the square flasher, it makes sense, most of the flashers I've ever replaced were round units. My guess was the square flashers didn't last long, I started working on this stuff in the early 70s, and don't remember changing many square old flasher units. Gene
Re: Three prong flasher [Re: poorboy] #2914584
04/25/21 03:53 AM
04/25/21 03:53 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The bracket is made to accept both, squared and round, hence the bent ends on center. As mentioned, squared used to be hazzards heavy duty one, and turnings allways round, but there is also round heavy duty labeled with a green band. So just one kind of bracket accepting both was made for easy.
If you want to get the bracket, don't search it for Mopar, but for Fords ( 60s Mustangs )... they are virtually the same except the price LOL
If ppl never inserted them back into the bracked it was because they were lazy to do it. Then if trying to remove the ashtray housing removed the bracket and never clipped it back
Hazzard gets the same bracket attached somewhere around brakes pedal brackets assembly.
