Re: Three prong flasher
[Re: 72440CUDA]
#2913313
04/22/21 09:31 AM
04/22/21 09:31 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Originally flashers are activated by bulb loads. they are allways energized, but untill bulbs are not sucking load the flasher won't be activated. I guess getting the led conversion, you got the electronic flasher for it, but STILL the signal should be there for them just like originals did
Of course hazzards are feeded from BATT source, while turning needs to get the ign key in ACC or RUN.
Assuming by your screen name you are working on a 72, you can check the red wire arriving to turning switch plug down the column. Put your ign swith on ACC and check for power on turning switch plug. It must be energized. If not, you have a damaged flasher or even unexistant one.
If you have power and still don't get turnings working, it could be the switch damaged... or bulbs
P.S.: the 3 ways flasher there as mentioned is for the ign switch courtesy light on column just at a side of the hazzard knob. It will turn on that light for around 8-15 seconds after get the dome light on and off ( doors opened or dimmer dome light on )
[Re: BDW]
#2913335
04/22/21 10:29 AM
04/22/21 10:29 AM
NachoRT74
Valencia, España
Jumping the red wire to the white wire into the column switch will make blink both rears with turning switch in rest position. That will discard the flasher of course, but not the turning switch completelly. On rest position turning switch gets rear lights linked to the white wire which is the normally closed position for the brake lights coming from pedal switch
then as mentioned on article, feeding each corner ( both greens, tan and brown ) and get the lights work but not through the switch which will confirm switch is bad.
[Re: IMGTX]
#2913466
04/22/21 02:55 PM
04/22/21 02:55 PM
NachoRT74
Valencia, España
the brake pedal one uses to be hazzard and USED to be the heavy duty squared version. It can be replaced by any round piece as far is heavy duty ( for 6 bulbs ). Tipically labeled with a green band
the one around ashtray it uses to be the turning signal, regular round flasher
[Re: poorboy]
#2914584
04/25/21 03:53 AM
04/25/21 03:53 AM
NachoRT74
Valencia, España
The bracket is made to accept both, squared and round, hence the bent ends on center. As mentioned, squared used to be hazzards heavy duty one, and turnings allways round, but there is also round heavy duty labeled with a green band. So just one kind of bracket accepting both was made for easy.
If you want to get the bracket, don't search it for Mopar, but for Fords ( 60s Mustangs )... they are virtually the same except the price LOL
If ppl never inserted them back into the bracked it was because they were lazy to do it. Then if trying to remove the ashtray housing removed the bracket and never clipped it back
Hazzard gets the same bracket attached somewhere around brakes pedal brackets assembly.
