Re: Door glass plastic slide
[Re: Silverbullet2]
#2915609
04/27/21 11:01 AM
04/27/21 11:01 AM
Posts: 306 Georgia
69bfan
Georgia
If you are referring to the mylar glass channel runs, it is very unlikely you will find any from any of the major vendors. They have been out of stock since last November. Your best bet is posting a wanted to buy ad and see if someone might have a set that they are willing to turn loose with. The going rate for the factory OEM pieces is $600 to $1000 for a pair at this time. No definite ETA on the reproductions and the question of the fit and finish is questionable once they do come back available.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
