Door glass plastic slide #2912786
04/21/21 09:27 AM
04/21/21 09:27 AM
Chicago-area Illinois
4mopower Offline OP
4mopower  Offline OP
On my 68 Barracuda the glides or plastic slides on the door glass tracks are wore out.
Are these available to replace? From?
Thanks, John.
Re: Door glass plastic slide [Re: 4mopower] #2912799
04/21/21 10:21 AM
04/21/21 10:21 AM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Megaparts has them.....Linky
Re: Door glass plastic slide [Re: ratroaster] #2912920
04/21/21 01:51 PM
04/21/21 01:51 PM
4mopower Offline OP
4mopower  Offline OP
Thanks I'll take a look.
Re: Door glass plastic slide [Re: 4mopower] #2915544
04/27/21 08:29 AM
04/27/21 08:29 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Apologize for hi-jacking but I need some, (probably 4) for a 68 road runner post car. Just looked at Megaparts website and didn't find them. Do I need to call them?
Re: Door glass plastic slide [Re: Silverbullet2] #2915609
04/27/21 11:01 AM
04/27/21 11:01 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
If you are referring to the mylar glass channel runs, it is very unlikely you will find any from any of the major vendors. They have been out of stock since last November. Your best bet is posting a wanted to buy ad and see if someone might have a set that they are willing to turn loose with. The going rate for the factory OEM pieces is $600 to $1000 for a pair at this time. No definite ETA on the reproductions and the question of the fit and finish is questionable once they do come back available.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Door glass plastic slide [Re: 69bfan] #2915619
04/27/21 11:16 AM
04/27/21 11:16 AM
North Carolina, USA
North Carolina, USA
Thanks 69Bfan. About what I was afraid of. I tried calling CI yesterday to get an ETA and never even got anybody to answer the phone.
Re: Door glass plastic slide [Re: Silverbullet2] #2916003
04/28/21 08:33 AM
04/28/21 08:33 AM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
Partsmix is supposed to have them soon...
Re: Door glass plastic slide [Re: Chally426] #2916497
04/29/21 11:18 AM
04/29/21 11:18 AM
North Carolina, USA
North Carolina, USA
YES! I see Partsmix is saying mid May. I think I salvaged enough from an extra set of doors to do my rear pop out windows, but It'd be better to have new ones for the front doors. Thanks!
