Dodge Ram starter will not come off, Help. #2912779
04/21/21 09:15 AM
04/21/21 09:15 AM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
Any ideas , 1995 Dodge Ram, starter all disconnected, 2 bolts and electrical, it will not budge at all, tried tapping with a hammer(a lot of tapping) still has not moved, any pro mechanic ideas as how to get it unstuck so I can put a new starter in, this is the original starter and never been unbolted, Thanks for any help, Dave
Re: Dodge Ram starter will not come off, Help. [Re: 340mouse] #2912795
04/21/21 10:16 AM
04/21/21 10:16 AM
Waynesboro, PA
cuda_tim Offline
cuda_tim  Offline
Waynesboro, PA
Can you move the flywheel? Perhaps it is just jammed.
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Dodge Ram starter will not come off, Help. [Re: cuda_tim] #2912798
04/21/21 10:20 AM
04/21/21 10:20 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Is there any studs that mounted the starter? If so heat that area with a torch. Might be salted up. Air hammer also will work. Double check the mounting bolts that you removed the needed two and not a bell housing lower bolt.
Re: Dodge Ram starter will not come off, Help. [Re: 340mouse] #2912826
04/21/21 11:46 AM
04/21/21 11:46 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just be CERTAIN that the 2 starter bolts are loosened, and not one of the trans bolts by mistake.
Re: Dodge Ram starter will not come off, Help. [Re: buildanother] #2912842
04/21/21 12:03 PM
04/21/21 12:03 PM
moparx Offline
moparx  Offline
i am guilty as charged ! and a BFH proved it with a broken starter ear. laugh2
beer
Re: Dodge Ram starter will not come off, Help. [Re: buildanother] #2912864
04/21/21 12:28 PM
04/21/21 12:28 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
THIS. I have dealt with some very rusty ones and they all came off without a lot of struggle--unless I had the wrong bolt on top undone. D'Oh.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Dodge Ram starter will not come off, Help. [Re: wingman] #2913068
04/21/21 06:21 PM
04/21/21 06:21 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Recently had mine off with engine pull out. It was snug in there, but some tapping with rubber mallet got it out. Trans shop that did my rebuild years ago put the hardware (nut and bolt) on like king kong, super tight.
Re: Dodge Ram starter will not come off, Help. [Re: njmopar] #2913163
04/21/21 08:50 PM
04/21/21 08:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I bought a 72 Coronet once that was a parts car, 318/727 with a factory trailer towing package. The starter had become one with the trans bell. Removed the bolts and broke the starter apart beating it with an 8lbs sledge hammer! Never did get it to separate, and yes, the starter bolts were out. The motor & trans were sitting on the ground while I was beating the starter with the sledge hammer. I really wanted that small block 727!
The car was about 10 years old and only had about 60,000 miles on it, it had been wrecked. I bought it as a package deal along with the 66 Coronet wagon the 72 had replaced. The 66 only had 120,000 miles on it, I dove it off and on for 3-4 years. The people bought both cars new to pull their camping trailer. Gene
