Re: A-body offset leaf spring kit
[Re: topside]
#2912139
04/19/21 11:16 PM
04/19/21 11:16 PM
Posts: 361 mississippi
lostdog
mississippi
What I noticed on my '72 Duster was that the 3/4" rear offset shackles helped with the rear spring section, but not at the front. Obvious if you think about it, but I didn't do that work. Needed front mount to be inboard, but I'm not sure what's available there. 275/60R15s on 8.5" rims (4.5" BS) were still tight at the front section. Oddly, my '74 with 8" factory Rallyes & 275s cleared the springs fine at both sections with a .250" spacer. Never rubbed. Moved spring eye back .250". My '70 is like Cab's deal; springs moved to the rails & mini-tubbed & stretched a bit (just cut), so a 13x31 slick fits fine on a 15x12 rim. There’s a front and back part to the offset kit. I have heard of guys just doing the back but that doesn’t make sense to me
[Re: greendart408]
#2912303
04/20/21 01:29 PM
04/20/21 01:29 PM
Posts: 553 Kentucky
clovis
Kentucky
I run Dr. Diff's offset kit on my Duster and a MT 28x10.50 slick is not an issue nor is a 275/65 MT Drag Radial on a 10" rim. I am pretty sure my offset is 3.75" on both sets of wheels. I run a Weld Wheel with the slicks and a Torque Thrust on the radials. I'm not sure if the later model Dusters have a little more space in the wheel well from the early years, as mine is a '75. I did have to shim the hanger to center the tire in the wheel well (front to back).
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: greendart408]
#2912392
04/20/21 04:04 PM
04/20/21 04:04 PM
lostdog
mississippi
All you need is the correct offset shackle and front hanger kit, no reason to chop up the car, imop. Plenty of room, my uncle has this exact setup on his duster. Runs a 275 pro m/t at the track and a 275 on a 15x10 on the street. Thanks ! this is the info I'm looking for
[Re: clovis]
#2912394
04/20/21 04:06 PM
04/20/21 04:06 PM
lostdog
mississippi
I run Dr. Diff's offset kit on my Duster and a MT 28x10.50 slick is not an issue nor is a 275/65 MT Drag Radial on a 10" rim. I am pretty sure my offset is 3.75" on both sets of wheels. I run a Weld Wheel with the slicks and a Torque Thrust on the radials. I'm not sure if the later model Dusters have a little more space in the wheel well from the early years, as mine is a '75. I did have to shim the hanger to center the tire in the wheel well (front to back). Thanks - so it looks like the information I got was accurate. I appreciate the help!
