68 C body front disc conversion kit? #2911910
04/19/21 11:55 AM
04/19/21 11:55 AM
Indianapolis In. usa
Quickrunner Offline OP
So my son just got a very nice original 68 Fury3 with manual drum brakes. Who makes a nice inexpensive front disc conversion for C body? Does not need to go to power, would just like to ditch the front drums and retain same spindles if possible. No high end willwood race type stuff, just a 318 Saturday night cruiser.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: 68 C body front disc conversion kit? [Re: Quickrunner] #2911914
04/19/21 12:25 PM
04/19/21 12:25 PM
Andrewh Offline
Andrewh  Offline
https://scarebird.com/index.php?route=product/product&path=64&product_id=255
this is the only conversion I am aware of.
it would honestly be better if you could find the 70-2 or the 73 spindles.
vans use the rotors for the 73. so they are still availble new.
dr diff I think makes the adapter bearings for the 70-2 spindles to use the 73 rotors.
Re: 68 C body front disc conversion kit? [Re: Quickrunner] #2912089
04/19/21 08:13 PM
04/19/21 08:13 PM
AndyF Offline
AndyF  Offline
I have a couple sets of the '73 disc knuckles sitting on the shelf. I took them to a swap meet last year but they didn't sell.
Re: 68 C body front disc conversion kit? [Re: AndyF] #2912109
04/19/21 09:03 PM
04/19/21 09:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
There's the solution right there. All the parts to complete the job are at your favorite parts store.
Those spindles will fit your drum spindle ball joints.
Kevin
Re: 68 C body front disc conversion kit? [Re: Twostick] #2912113
04/19/21 09:09 PM
04/19/21 09:09 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
F M or J body spindles and rotors/calipers (maybe find 5th Ave in wrecker ??) . . . all will fit and work . . use newer AL lightweight master cylinder . . . away you go . . . least cost option . . . or check with Dr. Diff for one of his kits . . .
Re: 68 C body front disc conversion kit? [Re: a12rag] #2912169
04/20/21 05:48 AM
04/20/21 05:48 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The F M J parts will fit A B E bodies but not C.
Check the Mopar Action disc conversion article.
Angry white pureblood male
Re: 68 C body front disc conversion kit? [Re: AndyF] #2912172
04/20/21 06:33 AM
04/20/21 06:33 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Definitely will buy a set if you’re willing to ship, I coincidentally also have a ‘68 Fury III and want to ditch the front drums. My car has a hot 440 in it and the brakes are marginal at best. Thanks!
Re: 68 C body front disc conversion kit? [Re: ruderunner] #2912229
04/20/21 11:04 AM
04/20/21 11:04 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The MA article has lots of issues in it.
Re: 68 C body front disc conversion kit? [Re: ruderunner] #2912239
04/20/21 11:26 AM
04/20/21 11:26 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Or go here, get your refreshments ready, it's a long read. Somewhere in there somebody called out the bearings and other part numbers you need:
https://www.forcbodiesonly.com/mopar-forum/threads/fuselage-drums-to-disc-brake-conversion.23988/
or here:
https://www.hotrod.com/articles/mopp-1107-c-body-disc-brake-conversion/#photo-01
Short story, buy the spindles, pick up the rest at the store. The hard part, you need the specific PDB to get adequate boost. Some guys claim to have gotten good results with the drum booster. Factories are CHEAP, they don't make changes lightly, go with the right parts. No matter how expensive you go, it's still cheaper than an accident, probably cheaper than your deductible.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 68 C body front disc conversion kit? [Re: Sniper] #2912378
04/20/21 03:48 PM
04/20/21 03:48 PM
a12rag Offline
a12rag  Offline
No issues . . . speaking real world experience . . . . and at time, these were dime a dozen at wrecking yards . . . cheap replacement parts (calipers/pads, etc), and you go with the bigger caliper bracket from "B" body, you can then go with bigger rotor . . . honestly, no issue in over 10k miles ! . . . and my car is non power brake car, no issue with a "tough pedal", very responsive and easy to use.
I would talk to Dr. Diff and check his website . . .
Re: 68 C body front disc conversion kit? [Re: 3hundred] #2912484
04/20/21 06:22 PM
04/20/21 06:22 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Found it! Post #3 has the part numbers. One of the other members is really happy with his SSBC conversion, allowed him to keep his 14" wheels.
https://www.forcbodiesonly.com/mopar-forum/threads/73-disc-brake-conversion-to-begin-soon.23330/
'69 300 Convertible
'16 300 S Hemi
Re: 68 C body front disc conversion kit? [Re: a12rag] #2912577
04/20/21 08:16 PM
04/20/21 08:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes and I have real world experience with the taller spindle he claims is an issue, it is not, has been debunked many times yet no retraction.
Re: 68 C body front disc conversion kit? [Re: a12rag] #2912695
04/20/21 11:01 PM
04/20/21 11:01 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What Cbody do you have an F,M,J spindle installed on?
Kevin
Re: 68 C body front disc conversion kit? [Re: Twostick] #2912697
04/20/21 11:04 PM
04/20/21 11:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Kevin
What C body is in the MA article?
For the record, I put them on a 64 300.
Re: 68 C body front disc conversion kit? [Re: Sniper] #2912738
04/21/21 07:03 AM
04/21/21 07:03 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That's why they fit then. A 64 is not a Cbody.
Cbody didn't start until 1965.
Any tricks required to use the FMJ on that 64?
Kevin
Re: 68 C body front disc conversion kit? [Re: Twostick] #2912762
04/21/21 08:46 AM
04/21/21 08:46 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Kevin
Call it what you want, it was a Cbody for all intents and purposes, had to trim the tie rod length to get the toe in spec, other than that nothing serious. Spindle heights were the same.
Re: 68 C body front disc conversion kit? [Re: Sniper] #2912827
04/21/21 11:47 AM
04/21/21 11:47 AM
moparx Offline
moparx  Offline
Kevin
i as well have real world experience using the FMJ spindle, probably close to 40 vehicles, and i did a 64 300 in the mix. as sniper said, the only issue [if you could really call it that] was trimming the tierod length.
i remember when i joined here, there was a big flap about using the tall spindle and "over extending" the upper ball joint. i proved to myself that was an impossibility by moving the suspension through it's entire range. [without the torsion bar installed and the bump stops removed]
beer
Re: 68 C body front disc conversion kit? [Re: moparx] #2913093
04/21/21 06:47 PM
04/21/21 06:47 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
And IIRC, Ebooger claimed it was a possibility, he didn't guarantee it would cause problems.
And a 64 really isn't a C body, not many chassis parts swap.
As for trimming tie rods to get toe in spec, you wouldn't have to do that on an A B E body because the steering arm is part of the ball joint, not the spindle.
Re: 68 C body front disc conversion kit? [Re: ruderunner] #2913122
04/21/21 07:45 PM
04/21/21 07:45 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
To quote Allpar "The C body dates from 1960, but was not officially named until 1965." https://www.allpar.com/threads/rear-wheel-drive-mopar-bodies-1957-2017.228756/#post-1085222854
On both the FMJ and the 64 C body the steering arm bolts to the spindle and the LBJ stud mounts to the steering arms. Right now I cannot remember which source I used for the steering arms after the conversion. I think the FMJ donor's. I did the swap back in 94 so the memory is dim these days.
Re: 68 C body front disc conversion kit? [Re: Twostick] #2913707
04/22/21 11:21 PM
04/22/21 11:21 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Kevin
Question, are lower balljoints available anymore? About 20 yrs ago when I replaced them on a '71 Chrysler I had, I was told they weren't being made anymore and I had gotten the last pair available (in this area at least).
Just curious.
John
