Dana 60 Power Lok vs. Detroit locker #2911984
04/19/21 04:01 PM
04/19/21 04:01 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
I'm sure this has been discussed. I need to pick one. Dana 60 with 35-spl axles.
This will be a street driver, probably a 400-451 and manual trans deal.
I'm going to fit the car with two sets of tires, one set will be the old Mickey Thompson N50-15
and the other set will be Nitto 325-50-15, 555r .
I guess I just need a push to either go with a clutch posi or the locker, not sure if I actually have a preference for a street car.
Re: Dana 60 Power Lok vs. Detroit locker [Re: hemienvy] #2911992
04/19/21 04:19 PM
04/19/21 04:19 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I went with the cheap, simple and no moving parts option: A spool!
'63 Dodge 330
11.19 @ 121 mph
Re: Dana 60 Power Lok vs. Detroit locker [Re: GY3] #2911996
04/19/21 04:23 PM
04/19/21 04:23 PM
Washington
Washington
Well I don't want a spool on this car.
Re: Dana 60 Power Lok vs. Detroit locker [Re: hemienvy] #2912012
04/19/21 05:30 PM
04/19/21 05:30 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i run the locker . no wear parts .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Dana 60 Power Lok vs. Detroit locker [Re: tex013] #2912013
04/19/21 05:37 PM
04/19/21 05:37 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I run the Detroit Locker in my '66 Charger hot rod. I ran many of the clutch-type sure-grips in my old Mopars years ago and they always gave me good service. The clutch type sure-grip is what I'd put in your street car. up
Re: Dana 60 Power Lok vs. Detroit locker [Re: hemienvy] #2912050
04/19/21 06:39 PM
04/19/21 06:39 PM
Have you ever rode or drove a car with a Detroit locker? If not you should before deciding twocents
I got one ride in a 1965 Mustang Shelby GT350 with a Detroit locker in it, the owner got on it a little making a left turn and I thought he broke the rear end and he laughed saying that cracking, jerking and popping was normal for that type rear end downshock puke
A good type clutch type posi is always my choice over a Detroit locker posi unit every time up
I put a 35 spline spool and axles in my old 8 3/4 for street use until I bent the housing bad enough to break the welds off of the ladder bars mounts welded onto the rear end axle tubes whiney
That would probably not happen with a clutch type posi shruggy
Re: Dana 60 Power Lok vs. Detroit locker [Re: hemienvy] #2912061
04/19/21 06:54 PM
04/19/21 06:54 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I am using the clutch type in my Dana 60 with 35 spline axles for street / strip use . So far it's been great for both.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Dana 60 Power Lok vs. Detroit locker [Re: Hemi Allstate] #2912064
04/19/21 06:58 PM
04/19/21 06:58 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I always liked the power-lok because it has 4 spiders but i did turn them into many pieces one time
Re: Dana 60 Power Lok vs. Detroit locker [Re: hemienvy] #2912097
04/19/21 08:34 PM
04/19/21 08:34 PM
WI
mopar873 Offline
mopar873  Offline
WI
Cab is right, a locker can be a clunky, shifty thing especially when cornering at low speed. That being said though, if you can tolerate the manners of them you might like them like I did mine. I had one in one of my Trans Ams with a manual and healthy LS and 35 spline Currie 9". I ran 28x10 bias plys on the street and on the track with that car and the Detroit Locker was dead reliable. But trying and find one to ride/drive in first is good advice, they're not for everyone.
Re: Dana 60 Power Lok vs. Detroit locker [Re: mopar873] #2912178
04/20/21 07:40 AM
04/20/21 07:40 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Detroit locker here, 35 spline in a Dana 60.
No clunking, no noises no nada at any speed.
Works great.
Re: Dana 60 Power Lok vs. Detroit locker [Re: mopar873] #2912182
04/20/21 07:43 AM
04/20/21 07:43 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
The Locker is a great choice...except for someone who can't handle some minor "clunking" noise the Locker might make when changing the forward/reverse direction. It's barely noticeable. The Dana that i ordered from Strange 20 yrs ago has a Locker. Zero regrets.
This section from the Owner's manual explains the "clunk". Not a good idea to shift from reverse to forward and immediately stomp on it. I'm sure that some 'experts' have done that only to cause damage to the unit because of the amount of backlash, and then claim that Lockers are no good.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Dana 60 Power Lok vs. Detroit locker [Re: jughed] #2912215
04/20/21 10:21 AM
04/20/21 10:21 AM
Washington
madscientist Offline
Washington
Locker. Hands down every time.
Re: Dana 60 Power Lok vs. Detroit locker [Re: madscientist] #2912218
04/20/21 10:32 AM
04/20/21 10:32 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Locker here too. up
Re: Dana 60 Power Lok vs. Detroit locker [Re: gsmopar] #2912250
04/20/21 11:40 AM
04/20/21 11:40 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If I remember right the locker was developed to make the outside wheel power in a turn whereas on an open or posi rear the inside wheel is always under power, the outside wheel is always trying to catch up. They didn’t use posi units in NASCAR for that reason. Ford developed the locker to utilize the advantage to make both wheels have equal power going around curves.
Re: Dana 60 Power Lok vs. Detroit locker [Re: cudaman1969] #2912262
04/20/21 12:01 PM
04/20/21 12:01 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Using a Detroit locker here in the Challenger, Dana 60, we've had no issues, fitted in 2014 IIRC. I can't hear it make a noise, (over the exhaust note anyway). And it doesn't feel "clunky" at all. I read a lot of stuff on here saying it would be horrible, noisy etc but in all honesty it has been fine and doesn't feel any different to the 4 pinion power lock that it replaced. Now a friend has a locker in a Cougar with a 9", behind a 347 and a five speed. That was fitted about 20 years ago and it is noisy. I'm wondering if the newer ones a different design?
Re: Dana 60 Power Lok vs. Detroit locker [Re: Tig] #2912415
04/20/21 04:36 PM
04/20/21 04:36 PM
Washington
Washington
The older lockers (like mine) are a bit more clunky than the newer units. Not nearly enough to make me change it.
Re: Dana 60 Power Lok vs. Detroit locker [Re: madscientist] #2912508
04/20/21 06:57 PM
04/20/21 06:57 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Had everything at one time or another, and everything has its purpose.
But the one thing i didn't like, and will never use again, is a Detroit locker.
Thing was downright creepy when you got out of the gas at speed on the street. Squirrelly. Almost unpredictable sometimes. No thanks.
Spool, sure grip, cone or clutch.. fine.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Dana 60 Power Lok vs. Detroit locker [Re: B3422W5] #2912586
04/20/21 08:32 PM
04/20/21 08:32 PM
Washington
Washington
Thank you guys, great info.
I have to say this about a locker though, I do not see how there could be any clunky business going in a straight line, either accel or decel.
Now the backlash phenomenon, I'm just not familiar with that.
Re: Dana 60 Power Lok vs. Detroit locker [Re: hemienvy] #2912617
04/20/21 09:10 PM
04/20/21 09:10 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I wonder sometimes if it is in how they are setup. I have more experience with various lockers for off roading / rock crawling. I have had some that you had barely any idea they were there and others as stated above that would jump half a lane when shifting or letting on/off the gas quickly. This was on stuff I bought used- the drop in lockers are all pretty similar in design and none of them are limited slip clutch type units.
I hear the same thing with detroits- some people report a good amount of noise and some quirkiness when turning and others swear it behaves nearly like an open rear.
Re: Dana 60 Power Lok vs. Detroit locker [Re: BigBlockGTS] #2912639
04/20/21 09:43 PM
04/20/21 09:43 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
Have a Locker in my Dana 60 and can't hear any clunking over the 3 1/2" exhaust. The car launches great on the street and at the track with 31 x 16.5 M/T Sportsman Pro's but is annoying on the street when getting on and off the throttle it almost changes lanes.
