Re: Dana 60 Power Lok vs. Detroit locker
[Re: hemienvy]
#2911992
04/19/21 04:19 PM
04/19/21 04:19 PM
Posts: 4,674 Wichita
GY3
Wichita
I'm sure this has been discussed. I need to pick one. Dana 60 with 35-spl axles. This will be a street driver, probably a 400-451 and manual trans deal. I'm going to fit the car with two sets of tires, one set will be the old Mickey Thompson N50-15 and the other set will be Nitto 325-50-15, 555r .
I guess I just need a push to either go with a clutch posi or the locker, not sure if I actually have a preference for a street car. I went with the cheap, simple and no moving parts option: A spool!
[Re: hemienvy]
#2912012
04/19/21 05:30 PM
04/19/21 05:30 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
i run the locker . no wear parts .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: hemienvy]
#2912061
04/19/21 06:54 PM
04/19/21 06:54 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I am using the clutch type in my Dana 60 with 35 spline axles for street / strip use . So far it's been great for both.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: jughed]
#2912215
04/20/21 10:21 AM
04/20/21 10:21 AM
Posts: 4,457 Washington
madscientist
Washington
Locker. Hands down every time.
[Re: gsmopar]
#2912250
04/20/21 11:40 AM
04/20/21 11:40 AM
Posts: 8,265 fredericksburg,va
cudaman1969
fredericksburg,va
If I remember right the locker was developed to make the outside wheel power in a turn whereas on an open or posi rear the inside wheel is always under power, the outside wheel is always trying to catch up. They didn’t use posi units in NASCAR for that reason. Ford developed the locker to utilize the advantage to make both wheels have equal power going around curves.
[Re: cudaman1969]
#2912262
04/20/21 12:01 PM
04/20/21 12:01 PM
Posts: 2,921 A shed in England
Tig
A shed in England
Using a Detroit locker here in the Challenger, Dana 60, we've had no issues, fitted in 2014 IIRC. I can't hear it make a noise, (over the exhaust note anyway). And it doesn't feel "clunky" at all. I read a lot of stuff on here saying it would be horrible, noisy etc but in all honesty it has been fine and doesn't feel any different to the 4 pinion power lock that it replaced. Now a friend has a locker in a Cougar with a 9", behind a 347 and a five speed. That was fitted about 20 years ago and it is noisy. I'm wondering if the newer ones a different design?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2912415
04/20/21 04:36 PM
04/20/21 04:36 PM
madscientist
Washington
Using a Detroit locker here in the Challenger, Dana 60, we've had no issues, fitted in 2014 IIRC. I can't hear it make a noise, (over the exhaust note anyway). And it doesn't feel "clunky" at all. I read a lot of stuff on here saying it would be horrible, noisy etc but in all honesty it has been fine and doesn't feel any different to the 4 pinion power lock that it replaced. Now a friend has a locker in a Cougar with a 9", behind a 347 and a five speed. That was fitted about 20 years ago and it is noisy. I'm wondering if the newer ones a different design? The older lockers (like mine) are a bit more clunky than the newer units. Not nearly enough to make me change it.
[Re: madscientist]
#2912508
04/20/21 06:57 PM
04/20/21 06:57 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Had everything at one time or another, and everything has its purpose. But the one thing i didn't like, and will never use again, is a Detroit locker. Thing was downright creepy when you got out of the gas at speed on the street. Squirrelly. Almost unpredictable sometimes. No thanks. Spool, sure grip, cone or clutch.. fine.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
