Wiring re-hab #2911146
04/16/21 11:14 PM
04/16/21 11:14 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
20 years of hacking, adding, subtracting..... gutted the car and started fresh with switch panel and wiring from Digital Delay. Great system and support!
Re: Wiring re-hab [Re: J_BODY] #2911153
04/16/21 11:24 PM
04/16/21 11:24 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Ok.... it’s criminal how hacked up this dash is. I’ll take little responsibility as I was 1200 miles away when this occurred oh so many years ago. Did a little aluminum magic with the old harbor freight aluminum welding rod for a new panel.
Re: Wiring re-hab [Re: J_BODY] #2911169
04/16/21 11:58 PM
04/16/21 11:58 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Do mine next? I’ll make you the best burger and Jalapeño poppers ever!
Re: Wiring re-hab [Re: gsmopar] #2911194
04/17/21 07:40 AM
04/17/21 07:40 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That looks great Jay! I just did something similar. I am not good at making wiring pretty but this all works and it is easy to add sensors or functions without much trouble.
Take in mind this covers the fuel injection, ignition, datalogging, and electrical for everything but the lights and wipers. Its still uglier than I wanted though lol.
68 Barracuda Formula S 340
Re: Wiring re-hab [Re: Bad340fish] #2911244
04/17/21 09:56 AM
04/17/21 09:56 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Think I have a drawer full of different junction blocks I ordered off Amazon...
couldn’t come up with a placement of the two step and rpm module so I drilled holes in the top of ye ole 6AL box and attached them there. Figured if I ruined it we’d buy the Grid laugh2
I thought the switch panel turned out rather nice. I hate when you vision something and it takes you days to come up with a plan to execute it.... and hope that it’s up to your expectations.
One thing on the switch panel I REALLY like is there is a bright red led halo around the start button that indicates the battery power is “ON”! Might eliminate those get strapped in oh crap the battery isn’t on moments smile
Re: Wiring re-hab [Re: gsmopar] #2911245
04/17/21 10:00 AM
04/17/21 10:00 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
With your skills and patience wiring will be a cakewalk Greg.....
Re: Wiring re-hab [Re: J_BODY] #2911286
04/17/21 11:22 AM
04/17/21 11:22 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Looks great, wiring comes out nice when its planned out. Or when its RE-Done it always looks better
....BAD A$$ STREET CAR.....
Re: Wiring re-hab [Re: n20mstr] #2911321
04/17/21 12:47 PM
04/17/21 12:47 PM
moparx Offline
moparx  Offline
a couple things i would like to see. please do not be offended, as this is offered as a safety tip.
i noticed a couple of wires going through drilled holes. those need grommets to protect the wire insulation.
also, i like to see wire bundles going through body cavities, like the kick panel area shown, protected by something [even that GM split plastic ridged stuff] so as to keep the bundle safe from rubbing on the edges of the cavity openings.
beer
Re: Wiring re-hab [Re: J_BODY] #2911331
04/17/21 01:11 PM
04/17/21 01:11 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Thanks buddy! I know that I need to do it. Rats nest of wires under the dash. I guess I’m making good use of my Electronics Engineering degree... blush
Well, the burger invite still stands.
Re: Wiring re-hab [Re: moparx] #2911332
04/17/21 01:12 PM
04/17/21 01:12 PM
Kirkland, Washington
Pacnorthcuda Offline
beer
Nylon oil pressure line inside the passenger compartment is a no no too.
Re: Wiring re-hab [Re: Pacnorthcuda] #2911348
04/17/21 02:22 PM
04/17/21 02:22 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Quote
Re: Wiring re-hab [Re: Pacnorthcuda] #2911376
04/17/21 04:32 PM
04/17/21 04:32 PM
CA
crackedback Offline
crackedback  Offline
CA
beer
That looks like the nylon vacuum line and oil pressure is a braided line.
Clean up looks nice J.
Re: Wiring re-hab [Re: crackedback] #2911443
04/17/21 09:01 PM
04/17/21 09:01 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
-2 steel for oil
Nylon is for the vacuum gauge smile
I might be a hack but not that hack!
Re: Wiring re-hab [Re: J_BODY] #2911881
04/19/21 10:19 AM
04/19/21 10:19 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I can't see the images but am eager to so, I'l have to check it out from the home 'puter.
