Re: Wiring re-hab
[Re: gsmopar]
#2911194
04/17/21 07:40 AM
04/17/21 07:40 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
That looks great Jay! I just did something similar. I am not good at making wiring pretty but this all works and it is easy to add sensors or functions without much trouble.
Take in mind this covers the fuel injection, ignition, datalogging, and electrical for everything but the lights and wipers. Its still uglier than I wanted though lol.
68 Barracuda Formula S 340
Re: Wiring re-hab
[Re: gsmopar]
#2911245
04/17/21 10:00 AM
04/17/21 10:00 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Do mine next? I’ll make you the best burger and Jalapeño poppers ever! With your skills and patience wiring will be a cakewalk Greg.....
Re: Wiring re-hab
[Re: n20mstr]
#2911321
04/17/21 12:47 PM
04/17/21 12:47 PM
Posts: 19,480 north of coder
moparx
a couple things i would like to see. please do not be offended, as this is offered as a safety tip. i noticed a couple of wires going through drilled holes. those need grommets to protect the wire insulation. also, i like to see wire bundles going through body cavities, like the kick panel area shown, protected by something [even that GM split plastic ridged stuff] so as to keep the bundle safe from rubbing on the edges of the cavity openings.
Re: Wiring re-hab
[Re: J_BODY]
#2911331
04/17/21 01:11 PM
04/17/21 01:11 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Do mine next? I’ll make you the best burger and Jalapeño poppers ever! With your skills and patience wiring will be a cakewalk Greg..... Thanks buddy! I know that I need to do it. Rats nest of wires under the dash. I guess I’m making good use of my Electronics Engineering degree... Well, the burger invite still stands.
Re: Wiring re-hab
[Re: moparx]
#2911332
04/17/21 01:12 PM
04/17/21 01:12 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
a couple things i would like to see. please do not be offended, as this is offered as a safety tip. i noticed a couple of wires going through drilled holes. those need grommets to protect the wire insulation. also, i like to see wire bundles going through body cavities, like the kick panel area shown, protected by something [even that GM split plastic ridged stuff] so as to keep the bundle safe from rubbing on the edges of the cavity openings. Nylon oil pressure line inside the passenger compartment is a no no too.
Re: Wiring re-hab
[Re: Pacnorthcuda]
#2911376
04/17/21 04:32 PM
04/17/21 04:32 PM
Posts: 2,079 CA
crackedback
CA
a couple things i would like to see. please do not be offended, as this is offered as a safety tip. i noticed a couple of wires going through drilled holes. those need grommets to protect the wire insulation. also, i like to see wire bundles going through body cavities, like the kick panel area shown, protected by something [even that GM split plastic ridged stuff] so as to keep the bundle safe from rubbing on the edges of the cavity openings. Nylon oil pressure line inside the passenger compartment is a no no too. That looks like the nylon vacuum line and oil pressure is a braided line. Clean up looks nice J.
Re: Wiring re-hab
[Re: crackedback]
#2911443
04/17/21 09:01 PM
04/17/21 09:01 PM
J_BODY
aZLiViN
-2 steel for oil Nylon is for the vacuum gauge I might be a hack but not that hack!
