cuda header panel question #291071
04/17/09 11:59 AM
04/17/09 11:59 AM
grand rapids mi. usa
P
Purestocker Offline OP
P
71-74 cuda header panels, are they all the same?? thank you in advance
Re: cuda header panel question [Re: Purestocker] #291072
04/17/09 07:26 PM
04/17/09 07:26 PM
cataclysm80 Offline
cataclysm80  Offline
no, They are Not all the same. There are 2 or more versions. I'd tell you more, but I haven't studied this as in depth as I would like yet. Perhaps I'll learn something here from other posters.
Tav
Re: cuda header panel question [Re: cataclysm80] #291073
04/19/09 09:30 PM
04/19/09 09:30 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
my guess would be that 72-74 is the same...71 might not be since they have the quad headlights...but u never know...
Re: cuda header panel question [Re: AARCONV] #291074
04/19/09 11:29 PM
04/19/09 11:29 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
No expert, but I think the 71 is different in regards to the vertical piece in front of the radiator is not drilled for the horns like the 72s and newer. Also, I believe the 5 slots where the grill is attached to the bottom of the header panel are inverted between the 71s and later years.
Re: cuda header panel question [Re: N9671X2] #291075
04/20/09 10:09 AM
04/20/09 10:09 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
You are correct regarding the slots. The black plastic retainers slide into the header panel in the opposite direction for the 72-4 header panels than they do for the 1971 header. You absolutely cannot use a 72-4 header panel for a 71 car, you will never be able to mount the grille because of the placement of the slots, they are shifted over from where they need to be to attach a 71 grille to it. The 72-4 panels have a bracket spot welded to the "arm" of the header panel. That bracket holds the dual horns for 72-4 cars. The horns on a 71 are mounted behind the washer bottle. That is the easiest way to tell if you have a 72-4 panel or a 71 panel, look for the bracket for the horns on the arm of the panel.
Re: cuda header panel question [Re: Purestocker] #291076
04/20/09 05:46 PM
04/20/09 05:46 PM
Jacksonville Florida
elitecustombody Offline
70 is year on it's own just like 71,but 72-74 is the same, so there were 3 different versions on the E-body header panels
Re: cuda header panel question [Re: elitecustombody] #291077
04/21/09 08:11 PM
04/21/09 08:11 PM
P
P
so is the grille/horn bracket bolted on in 71 and spot welded from 72-74??
Re: cuda header panel question [Re: Purestocker] #291078
04/22/09 12:03 AM
04/22/09 12:03 AM
cataclysm80 Offline
cataclysm80  Offline
In 71 the horns go on the inner fender, not on the header panel.
Tav
