Page 4 of 6 1 2 3 4 5 6
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2908545
04/09/21 10:24 PM
04/09/21 10:24 PM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
Dave I wouldn't be concerned about flow numbers on cylinder heads yet especially if you cant get the parts. Personally I would be concerned about getting a block, have you ordered one?
Re: Would like some advise on 2 different Hemi blocks [Re: boomerodell] #2908619
04/10/21 08:03 AM
04/10/21 08:03 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
No, but Bill Mitchell told me to get back with him in April as he had some blocks coming. I will be ordering within the next week or two.
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2908638
04/10/21 08:39 AM
04/10/21 08:39 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Originally Posted by mopar dave
Thanks for the reply and the info. They both look like good heads. I spoke with Best Machine about hemi heads and they suggested the Victor because of price and they come with bigger valves, but does bigger valves guarantee more flow in a hemi head? The stage V has a 168cc chamber and the Victor has 170cc chambers. Looks like the stage v head cnc'd flows 407cfm@.700 and the Victor flows 450cfm BM tells me. Its really hard to find much tech like flow numbers and such about the Hemi engine. Surprised there is not more info out there. Must be top secrete.
Dave, This is from 2009 FHO cnc Stage V replacement with 2.30 and 1.90 valves. I was offered the same valve size option from Modern but did't choose to do that. Just a little more info for you.
FHO CNC Ported Stage V Replacement Heads. For mild to wild street strip engines.
FHO CNC Replacement Head- Notes- application Blown Pro-Street Hemi - Use 45 degree wide seats for durability.
Note - Use stock intake and exhaust port openings.
Exhaust Port with 1.90" Valve Intake Port with 2.30" Valve
Flowed at 28" without tube. Flowed at 28"
.100" 61 .100" 75
.200" 135 .200" 159
.300" 187 .300" 248
.400" 230 .400" 315
.500" 258 .500" 384
.550" 267 .550" 412
.600" 279 .600" 435
.650" 287 .650" 453
.700" 295 .700" 467
.750" 298 .750" 469
.800" 301 .800" 471
Stage V Replacement Head with FHO CNC Porting.
Tests performed on Superflow 600 with FlowCom.
4.500" Bore Plate
Combustion Chamber 168cc
Intake Volume 241cc
Exhaust Volume 118cc
Intake Valve 2.30" Ferrea Titanium Tulip 11/32" Stem
Exhaust Valve 1.90 Ferrea Inconel TF Stainless Tulip 11/32" Stem
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2908660
04/10/21 09:47 AM
04/10/21 09:47 AM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
Good to hear. Stay on top of it because this hemi stuff is top secret and badass. The problem is most of these builders think that everybody they get calls from about a hemi is a tire kicker. It's understandable because these things are way expensive. But for me this is a project that will take a couple years so I need assurance that the correct parts are picked. I've beat my brain looking at flow numbers vs valve size vs builder and on! With that being said I'm learning that all these heads are capable of making the horsepower. So what ever you can get your hands on will work. Plus just like any engine its not just one component that makes it tick.
Re: Would like some advise on 2 different Hemi blocks [Re: boomerodell] #2908690
04/10/21 11:00 AM
04/10/21 11:00 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
I built a hemi dart years ago using the hooker 2-1/4 primary tube 4 inch collector original style headers. I did it the factory way. clearances shock tower, moved master cylinder on flex lines, cut down steering column outer tube, spaced K member down, elongated holes on steering box and moved it over, etc. even then i still had to have some header tubes modified to fit.
If i had to do over again I would use a motor plate, and have headers custom built. Put the motor in a place where valve covers come off, might still have to do offset master cylinder and some shock clearance work. But moving steering box and stacking k member, i wouldn't do that ever again. I built the car around the headers, next time build headers around the car.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Would like some advise on 2 different Hemi blocks [Re: HemiDart68] #2908726
04/10/21 12:34 PM
04/10/21 12:34 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the wealth of info guys, much needed. I'm planning on using the TTI A body hemi header . Tubes are only 1 1/8" thou, so should be a scunch easier to fit.
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2908761
04/10/21 02:54 PM
04/10/21 02:54 PM
Do you really mean 2 1/8 inch primary pipes?
Re: Would like some advise on 2 different Hemi blocks [Re: Cab_Burge] #2908863
04/10/21 10:33 PM
04/10/21 10:33 PM
Mt Morris Michigan
Mt Morris Michigan
Oops, yes 2 1/8. 1 1/8 would be kinda small.
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2909449
04/12/21 12:19 PM
04/12/21 12:19 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
My brand new stage 5's look like jewelry from barton. No chance a victor has the same power potential as a stage5 mullenium. That head comes stock with a 2.4 inch valve, and has the intake port to maximize it. If you want to be at a certain price point, its hard to look past the victor..... But you aint gonna out run a proper set up stage5
Re: Would like some advise on 2 different Hemi blocks [Re: cuda499] #2909489
04/12/21 02:52 PM
04/12/21 02:52 PM
Mt Morris Michigan
Mt Morris Michigan
The Stage v replacement head has about the same flow numbers as the Victor Hemi head, but costs about $2000 more/pr. Only difference i know of between the 2 is Stage V has 168cc chamber and the Victor has 170cc.
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2909494
04/12/21 03:03 PM
04/12/21 03:03 PM
The Stage V heads that Tim at FHO sells are not stock, he has them CNC first before selling them.
I'm not sure what they flow but I do know they will make 800 HP on a 572 C.I. 10.5 to 1 compression pump gas motor at 6500 RPM with a mild street solid roller cam with dual 4150 EFI throttle bodies up
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2909517
04/12/21 04:15 PM
04/12/21 04:15 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I agree Andy. A 572 wedge would be the smarter way if i just wanted to go fast. I want to go fast and look good doing it. You know those big valve covers with plug wires sticking out the top is super sexy. Always wanted to know what makes a Hemi tick and want to learn all i can about them. This will be an expensive project for sure, but will have plenty of money and lots of time once i'm retired. I think i'm gonna pull the trigger on the Bill Mitchell block real soon here. Still undecided on the stage 5 head or the Edelbrock victor JR Hemi head. I'm hearing more good about the Victor head at this point.
Very similar to my build. ProStreet car that I'd like to take to Drag Week. Mine is a 605, Indy Block, Indy CNC SR heads, 11:1 Pump Gas, mid size roller.
[Linked Image]Untitled by Greg Ault, on Flickr
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2909691
04/13/21 08:47 AM
04/13/21 08:47 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I was looking over on Scott Browns site and he has the stage 5 replacement heads assembled and complete for about $4700/pr. I honestly don't know what head would be needed on a 572 Hemi with between 11:1 and 12:1 compression to make roughly 900hp street/strip deal. That replacement Stage 5 head it advertised at flowing a tad over 400cfm.
I purchased my Stage V heads from Scott Great guy to work with, The only reason i would think about going with FHO is if you wanted to O-ring the heads for the intake, Its a diffrent offset to make up for the gasket, So you cannot just have the Heads from Scott machined to install O-rings, If your not worried about the O-rings and you will be using a standard gasket Scott will set you up with a great set of Heads.
Re: Would like some advise on 2 different Hemi blocks [Re: RATTRAP] #2909701
04/13/21 09:09 AM
04/13/21 09:09 AM
Mt Morris Michigan
Mt Morris Michigan
I was looking forward to talking to Scott about those heads as i used to be a regular customer of his 20 years ago. He doesn't answer the phone or return calls.
Re: Would like some advise on 2 different Hemi blocks [Re: gsmopar] #2909923
04/13/21 09:23 PM
04/13/21 09:23 PM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
gsmopar curious why you chose the sr over the hipo?
Re: Would like some advise on 2 different Hemi blocks [Re: RATTRAP] #2909927
04/13/21 09:37 PM
04/13/21 09:37 PM
Mt Morris Michigan
Mt Morris Michigan
Scott called tonight. Informed me there is a bigger head than the stage v replacement (not the millenium) that might be better for my combo. It has a much bigger intake valve, 2.40 vs the 2.25 in the replacement head. Also he thinks a cast iron Callies block would be a better foundation for a street/strip hemi. What do you guys think, cast iron Callies block or aluminum Bill Mitchell block would make a better street block and why?
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2909949
04/13/21 10:46 PM
04/13/21 10:46 PM
N/A gas motor, cast iron up
What blocks do the Pro Stocker run still?
They ain't aluminum as far as I know scope
Compact graphite iron I believe, maybe the middle word is not proper, dang my memory rant
Re: Would like some advise on 2 different Hemi blocks [Re: mopar dave] #2909997
04/14/21 08:10 AM
04/14/21 08:10 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Advantages of iron block: Cheaper, less hassle for daily driver, more stable for slightly more power.
Advantages of aluminum block: Repairable, better handling for daily driver, 200lbs lighter off the front of your A body.
I personally wouldn't mind giving up 15 HP or so to lose 200lbs off the nose.
Re: Would like some advise on 2 different Hemi blocks [Re: Cab_Burge] #2910014
04/14/21 09:43 AM
04/14/21 09:43 AM
Mt Morris Michigan
Mt Morris Michigan
I read some where that pro stockers have to run iron, because its in the rules. Read some old threads on here and some say they went from iron to aluminum and seen nothing on their time slip. So looks like the horse power penalty for aluminum is a wash with the lighter weight. Gonna research these Callies iron blocks some more. All i got so far is the Callies iron is a lot heavier than the aluminum block and about $1000 less.
Re: Would like some advise on 2 different Hemi blocks [Re: boomerodell] #2910016
04/14/21 09:51 AM
04/14/21 09:51 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Muscle Motors recommended it. They said CNC SR will make the power I want at a lower RPM.
