I hate bronze oil pump gears! #2908284
04/09/21 02:37 AM
04/09/21 02:37 AM
California
70Drop Offline OP
70Drop  Offline OP
California
I'm re-assembling my engine after a refresh. The bronze O/P drive gear has 0.020 backlash, so I need to replace it - again. It wouldn't bother me if this were a $30 part, but at $150 a pop, the costs add up! I'd appreciate any suggestions as to a longer-lasting gear or less-expensive alternative.
Re: I hate bronze oil pump gears! [Re: 70Drop] #2908300
04/09/21 04:49 AM
04/09/21 04:49 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Go to 'for a bodies only' there is a big discussion about, 'melonized hardened gears'!
One gear is steel and the other is iron, then all you have to know is what your cam is 'made of' to get the right one?
Most billet cams are steel 'of course' and some factory rollers are iron based cores...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: I hate bronze oil pump gears! [Re: 70Drop] #2908302
04/09/21 05:14 AM
04/09/21 05:14 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Do you run a collar on your distributor shaft? I installed one and it reduced the wear rate on my bronze gear dramatically by limiting the up and down movement of the gear.I was going to have my next gear cryogenicaly treated, but ended up using the melanized gear when i switched over to a new cam. I also installed a Milodon oil pump, which is claimed to take less power to spin at any given rpm.
Re: I hate bronze oil pump gears! [Re: jbc426] #2908309
04/09/21 06:48 AM
04/09/21 06:48 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know if you can do it on a big block or not but on my small block I drilled a small hole in the plug at the end of the galley, that hole squirts pressurized oil directly on the gear. I don't know if this will help or not because its a recent modification but I am sure it can't hurt. It doesn't have to be a big hole at all. I don't recall the size I used but I tried a few different sizes and was alarmed at the volume of oil that came out while pre-oiling. IIRC I used the smallest drill bit that I could use with a hand drill going into steel.
Also running thinner oil helps work that gear less.
68 Barracuda Formula S 340
Re: I hate bronze oil pump gears! [Re: 70Drop] #2908386
04/09/21 12:13 PM
04/09/21 12:13 PM
NC
440Jim Offline
440Jim  Offline
NC
Is this what race roller cam guys are running now-a-days?
Crane distributor gear - LINK
Re: I hate bronze oil pump gears! [Re: 440Jim] #2908388
04/09/21 12:19 PM
04/09/21 12:19 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Reading a lot about this issue while I wait for head gaskets. I have a milodon bronze gear, thinking I should buy the melanized gear instead, but has anyone run it with the MP hv pump? This drive gear issue worries me a bit, this engine will see -30 degree temperatures where even 5w30 flows like molasses, way more load on the drive gear at low temperatures.
I am going to fit the cam up and see what the gear mesh and lash are like.
Re: I hate bronze oil pump gears! [Re: 440Jim] #2908399
04/09/21 01:01 PM
04/09/21 01:01 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
That's what I'm running! Hundreds of dragstrip passes, over 7,000 miles and showing virtually no wear.
'63 Dodge 330
11.19 @ 121 mph
Re: I hate bronze oil pump gears! [Re: jbc426] #2908400
04/09/21 01:06 PM
04/09/21 01:06 PM
California
70Drop Offline OP
70Drop  Offline OP
California
I'm running a collar. It helps keep my timing stable, but I'm not sure if it's helped with gear wear
Re: I hate bronze oil pump gears! [Re: 70Drop] #2908402
04/09/21 01:08 PM
04/09/21 01:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Howard's sells just the gear (without the shaft) for $76.95.
Inexplicably, Howards uses the same marketing photograph as CAT uses.
The CAT part is $19.95, free shipping.
You have to press the gear off and on, yourself.
I wouldn't be super surprised to learn that not only is the marketing photograph the same, but the part itself just might be the same too.
I should probably buy them both and see.
The MP part used to be manufactured locally in Mt. Clemens MI, but I am not sure about nowadays, and the "made in" sticker might have only referred
to assembly and packaging....for all I know it may have had a $19.95 imported
gear on it all along.
Rich H.
Esse Quam Videri
Re: I hate bronze oil pump gears! [Re: 70Drop] #2908406
04/09/21 01:15 PM
04/09/21 01:15 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Both the the Slant 6 and Chevy stovebolt cam drives appear to benefit by a pressure squirt directly to the mating surfaces.
I have a feeling (and no more than that) that the rotating gears' centrifugal force tends to spin off any splash oil, and more may decrease surface temperature.
Metering sizes: anything above .030" is supposed to be safer from debris floating in the oil which may block it.
Boffin Emeritus
Re: I hate bronze oil pump gears! [Re: polyspheric] #2908469
04/09/21 05:22 PM
04/09/21 05:22 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Talk is cheap ... post a link !!
Re: I hate bronze oil pump gears! [Re: Stanton] #2908490
04/09/21 07:08 PM
04/09/21 07:08 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Put marking compound on the new one and look at the pattern. You can't move the bushing hole, but you can move the cam forward, or backwards, and the gear up or down. When it's all centered, you'll have way less play, and way less wear. No different than the diff
Re: I hate bronze oil pump gears! [Re: dthemi] #2908499
04/09/21 07:35 PM
04/09/21 07:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My used gear has 700+ passes on it. Looks fine.
Doug
Re: I hate bronze oil pump gears! [Re: dvw] #2908511
04/09/21 08:17 PM
04/09/21 08:17 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Doug
What material, what oil pump?
Re: I hate bronze oil pump gears! [Re: Uberpube] #2908527
04/09/21 09:28 PM
04/09/21 09:28 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I know this is AMC but it illustrates what lengths AMC went to when it came to lubricating the oil pump drive gear.
AMC Oiling Video
Re: I hate bronze oil pump gears! [Re: 6PakBee] #2908529
04/09/21 09:34 PM
04/09/21 09:34 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
This accomplishes absolutely nothing on helical cut gears.The clearance is what it is. The only way to adjust clearance is with a gear that's cut oversize or undersize. And the same applies to straight-cut gears.
Re: I hate bronze oil pump gears! [Re: Uberpube] #2908531
04/09/21 09:36 PM
04/09/21 09:36 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I trashed one with only 3k street miles and a couple strip passes. I was running 20W50 Brad Penn the whole time and never even thought about it. Was recommended, just like in this thread, that I check contact pattern on the new gear before running it. Haven't done that yet.
Re: I hate bronze oil pump gears! [Re: MarkZ] #2908558
04/09/21 11:10 PM
04/09/21 11:10 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I saw one melonized gear used once on a solid roller....small block chevy, it put shattered hardened gear through out the engine, I'll never use one . my twocents
Re: I hate bronze oil pump gears! [Re: Uberpube] #2908595
04/10/21 05:15 AM
04/10/21 05:15 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Bonze gear. Indy single line pump cover with the Melling thick rotor pump. 5w20/30 JR1 synthetic. Cam endplay is controlled with a Jessel belt dive.
Doug
Re: I hate bronze oil pump gears! [Re: dvw] #2908645
04/10/21 09:18 AM
04/10/21 09:18 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Doug
Doug
Maybe thrust has some thing to do with it I have a Milodon gear drive that sets thrust of the cam and the bronze gear in my 512 is sill in good shape too.
