Ammeter moves violently when turn signals on #2907929
04/08/21 09:13 AM
04/08/21 09:13 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
As stated, but functions normally otherwise.
Should I be looking for a short in that system, or can their be another
problem?
This is on a 70 Charger with a Painless re-wire.
Thanks, Joe
PS Turn signal lights work OK
PPS Just remembered we changed rear taillights to have dual filaments in all three bulbs each side,
could there be a feedback from that???
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2907935
04/08/21 09:31 AM
04/08/21 09:31 AM
Penna
70satelliteguy Offline
Penna
On my 68 Charger it moves also when turn signal works but not violently. Never seemed to hurt anything.
Re: Ammeter moves violently when turn signals on [Re: 70satelliteguy] #2907938
04/08/21 09:44 AM
04/08/21 09:44 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Mine goes from one extreme to the other in time with the signals,
it can't be good for the gauge's lifespan!!!
Thanks, Joe
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2907964
04/08/21 11:11 AM
04/08/21 11:11 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The gauge will survive LOL. the ammeter is hard to beat.
How does it go with hazzards and brakes?
Does it go from C to D (+40 to -40 )? from D to C (-40 to + 40 )? I meant... which side of the amm flicks to first ? does it makes the all full sweep from side to side ?
Re: Ammeter moves violently when turn signals on [Re: NachoRT74] #2907979
04/08/21 11:56 AM
04/08/21 11:56 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
No Hazards, when we rewired, decided to simplify that signal/hazard complication.
The Charger's at my son's garage, he'll help answer those questions wen he returns my call.
Thanks, Joe
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2907993
04/08/21 12:28 PM
04/08/21 12:28 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
OK, spoke with my son:
Brakes; -20 to +20 with neg. first
Turns; 0 to +40 for about 3-4 cycles, then -20 to +20 for a while , then back to 0 to +40
Puzzle for you Nacho, LOL thank you, Joe
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2908005
04/08/21 01:01 PM
04/08/21 01:01 PM
CA
crackedback Offline
crackedback  Offline
CA
Where is the fusebox wired into the system along the charge line route?
OEM fuseblock was pulled from the welded splice between the alternator and ammeter. From what you wrote regarding brakes it appears to be on the same side as OEM.
stock alternator at idle will not have the required output for anything other than a dome light most of the time. smile Just a bad set up from the original design.
Sensitive gauge and slow to respond VR possible.
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2908007
04/08/21 01:09 PM
04/08/21 01:09 PM
Adding two more bulbs increased the amp draw to light them up, correct shruggy
Pull those two bulbs out and see how much that changes the amp meter swing scope
I would also look at all the grounds to the turn signals, improving them will reduce the current draw if the grounds are not good wrench twocents
Re: Ammeter moves violently when turn signals on [Re: Cab_Burge] #2908010
04/08/21 01:18 PM
04/08/21 01:18 PM
CA
crackedback Offline
crackedback  Offline
CA
Re: Ammeter moves violently when turn signals on [Re: Cab_Burge] #2908013
04/08/21 01:21 PM
04/08/21 01:21 PM
moparx Offline
moparx  Offline
also look close at the connection for the turn signal switch at the bottom of the column for looseness or corrosion.
this place has been an unending source of problems in my experience over the years on countless cars.
just something else to check.
beer
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2908031
04/08/21 02:15 PM
04/08/21 02:15 PM
IMGTX Offline
IMGTX  Offline
You mentioned a painless rewire.
In the OEM wiring the ammeter is located between the battery and everything else. This is so the ammeter is only registering what is going in or out of the battery.
When the car is operating and the battery is charged the ammeter will read almost nil. All current in the system used by primary systems and accessories will be supplied by the alternator not the battery. If the alternator fails the battery supplies the current and the ammeter gauge swings to discharge.
If the ammeter isn't the last thing before the battery it can cause violent swings in the gauge when accessories are energized.
If it is correctly wired and the swings are violent it could be a bad gauge or sluggish Voltage Regulator as somebody already pointed out.
Did you switch to an Electronic Voltage Regulator?
Re: Ammeter moves violently when turn signals on [Re: IMGTX] #2908046
04/08/21 02:47 PM
04/08/21 02:47 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks for the input, have the electronic regulator, but I have a spare I'll patch in.
I have good grounds to the lights, added gr. wires to the front turn housings.
I'll pull the extra brake and turn lights from the rear too and see what happens.
Thanks again, I shall return.....
Joe
PS, I'll look at the schematic to see where the ammeter is in relation to batt./alt.
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2908059
04/08/21 03:21 PM
04/08/21 03:21 PM
IMGTX Offline
IMGTX  Offline
Make sure the Electronic VR is wired correctly.
If it is a 72-80's Mopar 2 wire style it should be wired with the green wire (side of the triangular connector) straight to a field on the alternator.
The blue (middle of the triangular connector) connected to the other field and the ignition power feed.
I have seen people mis-wire regulators and get results that charged the battery but acted really weird.
If it is not the 72-80's mopar style and is an electronic version of the 1 wire field wire system, make sure the 1 field wire is un-interupted to the alternator. Nothing else should be connected to it.
If you feel like the gauge is the problem but it is wired correctly just hook another ammeter near the battery. An inline mopar or clamp on test meter should give you an idea if it is a wacky gauge.
Just a thought.
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2908069
04/08/21 03:40 PM
04/08/21 03:40 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
this is the factory setup on all Mopars up to 75/76... just diff bulkhead disposition ( based on 71/74 B bodies and all E bodies )
Re: Ammeter moves violently when turn signals on [Re: NachoRT74] #2908130
04/08/21 06:55 PM
04/08/21 06:55 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Seems like the older stuff is more sensitive but then into the 80's & 90's the needle barely moved
Re: Ammeter moves violently when turn signals on [Re: 500ciDuster] #2908159
04/08/21 08:11 PM
04/08/21 08:11 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Keep in mind the state of the battery has a big influence on he flow of current............
Re: Ammeter moves violently when turn signals on [Re: Pacnorthcuda] #2908164
04/08/21 08:20 PM
04/08/21 08:20 PM
before you rewired was it not acting up?
Re: Ammeter moves violently when turn signals on [Re: jlatessa] #2908173
04/08/21 08:48 PM
04/08/21 08:48 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Quote
did you change and wire the sockets correctly at the same time ??? A dual filament (contact) bulb in a single filament (constact) socket can create a problem wink beer
Re: Ammeter moves violently when turn signals on [Re: Cab_Burge] #2908224
04/08/21 11:08 PM
04/08/21 11:08 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Originally Posted by Cab_Burge
Adding wo more bulbs increased the amp draw to light them up, correct shruggy
Pull two bulbs out and see how much that changes the amp meter swing scope
First place I'd start since it's easiest to perform/diagnose.
Re: Ammeter moves violently when turn signals on [Re: PhillyRag] #2908362
04/09/21 10:50 AM
04/09/21 10:50 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Yes on the socket change for the dual filament bulbs, my son is pulling those bulbs and will see if it improves the needle fluctuation....
Also, when rewiring the car, I became anal about the grounds and when the front signal housing grounds became intermittent because of age,
I wired two extra wires to the housings, those should be good.
Will try the other ideas when I get to the car.
Thanks folks, Joe
