Ammeter moves violently when turn signals on
#2907929
04/08/21 09:13 AM
04/08/21 09:13 AM
Posts: 1,317 Ohio
jlatessa
Ohio
As stated, but functions normally otherwise. Should I be looking for a short in that system, or can their be another problem?
This is on a 70 Charger with a Painless re-wire.
Thanks, Joe
PS Turn signal lights work OK
PPS Just remembered we changed rear taillights to have dual filaments in all three bulbs each side, could there be a feedback from that???
Re: Ammeter moves violently when turn signals on
[Re: jlatessa]
#2907964
04/08/21 11:11 AM
04/08/21 11:11 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
The gauge will survive LOL. the ammeter is hard to beat.
How does it go with hazzards and brakes?
Does it go from C to D (+40 to -40 )? from D to C (-40 to + 40 )? I meant... which side of the amm flicks to first ? does it makes the all full sweep from side to side ?
[Re: jlatessa]
#2908005
04/08/21 01:01 PM
04/08/21 01:01 PM
Posts: 2,075 CA
crackedback
CA
Where is the fusebox wired into the system along the charge line route? OEM fuseblock was pulled from the welded splice between the alternator and ammeter. From what you wrote regarding brakes it appears to be on the same side as OEM. stock alternator at idle will not have the required output for anything other than a dome light most of the time. Just a bad set up from the original design. Sensitive gauge and slow to respond VR possible.
[Re: jlatessa]
#2908007
04/08/21 01:09 PM
04/08/21 01:09 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
Adding two more bulbs increased the amp draw to light them up, correct Pull those two bulbs out and see how much that changes the amp meter swing I would also look at all the grounds to the turn signals, improving them will reduce the current draw if the grounds are not good
[Re: Cab_Burge]
#2908010
04/08/21 01:18 PM
04/08/21 01:18 PM
Posts: 2,075 CA
crackedback
CA
[Re: Cab_Burge]
#2908013
04/08/21 01:21 PM
04/08/21 01:21 PM
Posts: 19,405 north of coder
moparx
also look close at the connection for the turn signal switch at the bottom of the column for looseness or corrosion. this place has been an unending source of problems in my experience over the years on countless cars. just something else to check.
[Re: jlatessa]
#2908069
04/08/21 03:40 PM
04/08/21 03:40 PM
NachoRT74
Valencia, España
PS, I'll look at the schematic to see where the ammeter is in relation to batt./alt.
this is the factory setup on all Mopars up to 75/76... just diff bulkhead disposition ( based on 71/74 B bodies and all E bodies )
[Re: Pacnorthcuda]
#2908164
04/08/21 08:20 PM
04/08/21 08:20 PM
RapidRobert
before you rewired was it not acting up?
