which elctronic ign mod do you use??
#290762
04/16/09 11:05 PM
04/16/09 11:05 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
One basically a warmed over stock motor say 350-400 hp would you stay with the factory black electronic ignition module or step up to the MP orange box...Are the advantages worth it or?? Some opinions would be greatly appreciated..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: which elctronic ign mod do you use??
[Re: 72N96RR]
#290763
04/16/09 11:08 PM
04/16/09 11:08 PM
Posts: 85 Rhode Island
GoodfellaHenry70
Rhode Island
I run Orange (Proudly made in Me'heco)Boxes.
I keep a black or orange box as spares in each car.
I think the black box provides steady spark up to 5000rpm and the orange good to 6500rpm.
"No big deal...It's called Advanced Dilusionary schizophrenia with involuntary narcissistic rage."
Just call me Hank.
[Re: 72N96RR]
#290764
04/16/09 11:09 PM
04/16/09 11:09 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
If you are going to buy a better box, then I'd say go with the chrome box. The orange is only marginally better than a stock one.
I am using an FBO ignition box. It has similiar specs to a crome box.
[Re: 72N96RR]
#290765
04/16/09 11:59 PM
04/16/09 11:59 PM
RapidRobert
I would not buy the orange box. Either the FBO ecu/ballast or the MP chrome box & I believe it takes the 1.25 ohm MP single ballast
[Re: MoparforLife]
#290769
04/17/09 07:57 PM
04/17/09 07:57 PM
Posts: 1,044 minnesota
president61
minnesota
There waas a write up in the Mopar mags a few years ago that stated that if your if your present ignition is working that the only real advantage to the higher priced systems is more bells and whistles. I had at teh time I read this already switched from a home recurved OEM distriutor and chrome box to a Crane HI6 and MSD billet distributor. What did I gain nothing in performance or runnability. I gained the ease of setting the advance curve (whoopty doo) as if that is something that you do every day. Once it is set it is set.
I agree that high dollar stuff is over-rated. I'm not 80 years old either. I switched my Satelite over to electronic 17 years ago using stock parts from a junk yard. I haven't had a lick of problem ever. My 383 will rev to 6000 no problem too. A friend of mine had one of those MSD boxes take a poop at the track and it set him back $250!
[Re: president61]
#290770
04/17/09 08:36 PM
04/17/09 08:36 PM
Posts: 7,506 Az
Crizila
Az
I went with a D.U.I. system. I don't need no stinking boxes, balasts, coil brackets, or anything else ignition related cluttering up my fire wall. One 12vlt wire ( and a tach wire) is all that's needed. The curve is easily adjustable and it puts out 50K+ open voltage on my distributor machine. Lights them all, every time!
Fastest 300
[Re: MoreParts]
#290774
04/17/09 10:40 PM
04/17/09 10:40 PM
Just picked up a ProComp hei dist on Ebay, $46. and a cheap Summit hei coil, no ballast. 2 wire hookup, fired right up.
#290775
04/17/09 10:44 PM
04/17/09 10:44 PM
Posts: 565 IA
landon1
IA
I have the Procomp HEI as well, but with an Accel Superstock (no ballast)...great set-up for a street car imo
'71 Satellite Sebring 440
[Re: Hotwheelsjr]
#290779
04/18/09 06:23 PM
04/18/09 06:23 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
i run a MSD box without troubles. the reason i like the aftermarket boxes because you can easily add advance and retard functions from the digital boxes, and actually set them up to do it at a certain rpm, or get add on boxes for the older non digital ones. one other think people forget about multi-spark is it will usually improve idle quality especially if your AF mix isn't perfect.
perception is 90% of reality
[Re: Mr T2U]
#290780
04/18/09 07:26 PM
04/18/09 07:26 PM
I've run nothing but msd systems in my cars for years with no problems or breakdowns,same can't be said for mopar ignitions..i think its pretty sad when you need to carry spare ignition parts in the trunk for fear of a breakdown..
