which elctronic ign mod do you use?? #290762
04/16/09 11:05 PM
04/16/09 11:05 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
One basically a warmed over stock motor say 350-400 hp would you stay with the factory black electronic ignition module or step up to the MP orange box...Are the advantages worth it or??
Some opinions would be greatly appreciated..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: which elctronic ign mod do you use?? [Re: 72N96RR] #290763
04/16/09 11:08 PM
04/16/09 11:08 PM
Rhode Island
GoodfellaHenry70 Offline
Rhode Island
I run Orange (Proudly made in Me'heco)Boxes.
I keep a black or orange box as spares in each car.
I think the black box provides steady spark up to 5000rpm and the orange good to 6500rpm.
"No big deal...It's called Advanced Dilusionary schizophrenia with involuntary narcissistic rage." Just call me Hank.
Re: which elctronic ign mod do you use?? [Re: 72N96RR] #290764
04/16/09 11:09 PM
04/16/09 11:09 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
If you are going to buy a better box, then I'd say go with the chrome box. The orange is only marginally better than a stock one.
I am using an FBO ignition box. It has similiar specs to a crome box.
Re: which elctronic ign mod do you use?? [Re: 72N96RR] #290765
04/16/09 11:59 PM
04/16/09 11:59 PM
I would not buy the orange box. Either the FBO ecu/ballast or the MP chrome box & I believe it takes the 1.25 ohm MP single ballast
Re: which elctronic ign mod do you use?? [Re: RapidRobert] #290766
04/17/09 12:42 PM
04/17/09 12:42 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I ran a Wells box purchased at Auzone Zone for years. Car ran 11.08 with it. I bought in to the idea it wasn't good enough. Purchased a FBO box and coil. The car still ran 11.08. If I needed a box a new box I'd go to AZ and save $50. JMO Jim
Re: which elctronic ign mod do you use?? [Re: 72N96RR] #290767
04/17/09 07:22 PM
04/17/09 07:22 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
I love the instant starts.
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: which elctronic ign mod do you use?? [Re: 472 R/T SE] #290768
04/17/09 07:28 PM
04/17/09 07:28 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
There waas a write up in the Mopar mags a few years ago that stated that if your if your present ignition is working that the only real advantage to the higher priced systems is more bells and whistles.
I had at teh time I read this already switched from a home recurved OEM distriutor and chrome box to a Crane HI6 and MSD billet distributor. What did I gain nothing in performance or runnability. I gained the ease of setting the advance curve (whoopty doo) as if that is something that you do every day. Once it is set it is set.
Re: which elctronic ign mod do you use?? [Re: MoparforLife] #290769
04/17/09 07:57 PM
04/17/09 07:57 PM
minnesota
P
president61 Offline
president61  Offline
P
minnesota
I agree that high dollar stuff is over-rated. I'm not 80 years old either. I switched my Satelite over to electronic 17 years ago using stock parts from a junk yard. I haven't had a lick of problem ever. My 383 will rev to 6000 no problem too. A friend of mine had one of those MSD boxes take a poop at the track and it set him back $250!
Re: which elctronic ign mod do you use?? [Re: president61] #290770
04/17/09 08:36 PM
04/17/09 08:36 PM
Az
Crizila Offline
Crizila  Offline
Az
I went with a D.U.I. system. I don't need no stinking boxes, balasts, coil brackets, or anything else ignition related cluttering up my fire wall. One 12vlt wire ( and a tach wire) is all that's needed. The curve is easily adjustable and it puts out 50K+ open voltage on my distributor machine. Lights them all, every time!
Fastest 300
Re: which elctronic ign mod do you use?? [Re: Crizila] #290771
04/17/09 09:04 PM
04/17/09 09:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the orange box on my 63 with the Acell super coil and I use a 1 ohm ballast. It was on my boys Dart and I took it when he switched to MSD. He ran no faster with the MSD. It has been on one of our cars since 1999. Ron
Re: which elctronic ign mod do you use?? [Re: rt66jim] #290772
04/17/09 09:07 PM
04/17/09 09:07 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I agree. I have a wells box on my car and it runs strong and starts instantly. I do have an Accel Super Stock Street coil though.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: which elctronic ign mod do you use?? [Re: goldduster318] #290773
04/17/09 10:13 PM
04/17/09 10:13 PM
MoreParts Offline
MoreParts  Offline
I use a Pertronix. Had it for around 10 years, no problems. They're butt cheap and look stock.
Re: which elctronic ign mod do you use?? [Re: MoreParts] #290774
04/17/09 10:40 PM
04/17/09 10:40 PM
Just picked up a ProComp hei dist on Ebay, $46. and a cheap Summit hei coil, no ballast. 2 wire hookup, fired right up.
Re: which elctronic ign mod do you use?? #290775
04/17/09 10:44 PM
04/17/09 10:44 PM
IA
landon1 Offline
landon1  Offline
IA
I have the Procomp HEI as well, but with an Accel Superstock (no ballast)...great set-up for a street car imo
'71 Satellite Sebring 440
Re: which elctronic ign mod do you use?? [Re: landon1] #290776
04/18/09 01:04 AM
04/18/09 01:04 AM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
I learned about the HEI conversion (using the stock electronic mopar distributor) over on the slant 6 forum, and did the mod on my '73 dart 318. It's been runnign with no problems what so ever for 2 years now. Fast starts, and strong sparks. Does seem to get a trifle weak above 5000 rpm, but I'm sold.
Re: which elctronic ign mod do you use?? [Re: polkat] #290777
04/18/09 01:11 AM
04/18/09 01:11 AM
Spokane Wa
CrazyRocker70 Offline
Spokane Wa
i saw a guy with a 340 powered duster running a gm 1 wire alternator and mallory distributor, anyone else seen this or have any insight on it?
Re: which elctronic ign mod do you use?? [Re: CrazyRocker70] #290778
04/18/09 04:50 PM
04/18/09 04:50 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
There's been quite a debate over the years about the reliability of the orange box. I ran one for a little while before I switched over to a chrome box in my Demon. Ran the chrome box in my Demon for about 15 years with no issues. I now run MSD in the Demon, but run the chrome box in both my son's '73 RR (400) and my daughter's '67 B-cuda (225). Knock on wood...no problems with either.
Re: which elctronic ign mod do you use?? [Re: Hotwheelsjr] #290779
04/18/09 06:23 PM
04/18/09 06:23 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i run a MSD box without troubles.
the reason i like the aftermarket boxes because you can easily add advance and retard functions from the digital boxes, and actually set them up to do it at a certain rpm, or get add on boxes for the older non digital ones.
one other think people forget about multi-spark is it will usually improve idle quality especially if your AF mix isn't perfect.
perception is 90% of reality
Re: which elctronic ign mod do you use?? [Re: Mr T2U] #290780
04/18/09 07:26 PM
04/18/09 07:26 PM
I've run nothing but msd systems in my cars for years with no problems or breakdowns,same can't be said for mopar ignitions..i think its pretty sad when you need to carry spare ignition parts in the trunk for fear of a breakdown..
Re: which elctronic ign mod do you use?? [Re: Mr T2U] #290781
04/18/09 09:57 PM
04/18/09 09:57 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have been running a chrome box that was used when I got it 10 years ago with no problems. I like to keep it simple, unless your running nitrous or forced induction then its worth stepping up.
