how do you remove a12 idle solenoid bracket #290619
04/16/09 08:36 PM
04/16/09 08:36 PM
Anonymous OP
Anonymous OP
i need to remove the bracket that holds the idle solenoid to the intake manifold, how do you get it off cleanly? any help greatly appreciated.
Re: how do you remove a12 idle solenoid bracket #290620
04/16/09 08:48 PM
04/16/09 08:48 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Are you trying to remove the bracket that is spot welded to the solenoid body?
Re: how do you remove a12 idle solenoid bracket [Re: Snoopy] #290621
04/16/09 08:56 PM
04/16/09 08:56 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Unbolt it?
Re: how do you remove a12 idle solenoid bracket [Re: Snoopy] #290622
04/16/09 09:17 PM
04/16/09 09:17 PM
sixbbl69 Offline
sixbbl69  Offline
very easy, drill bit or you could buy a new one .myself i would just get another new one out of my file cabinet if i needed it.i believe i gave $6.00 ea. for the 3 i bought at Mid city Chrysler Plymouth in Jax. Fla. never needed them.i gave one to a good friend a few yrs ago.
Re: how do you remove a12 idle solenoid bracket #290623
04/16/09 09:25 PM
04/16/09 09:25 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Why would you want to remove just the bracket?
Re: how do you remove a12 idle solenoid bracket [Re: ScottSmith_Harms] #290624
04/17/09 08:44 AM
04/17/09 08:44 AM
Anonymous OP
Anonymous OP
i found a nos one without the bracket.
so i want to remove my old unworking bracket and transfer it over to the new one.
Re: how do you remove a12 idle solenoid bracket [Re: Snoopy] #290625
04/17/09 08:45 AM
04/17/09 08:45 AM
Anonymous OP
Anonymous OP
yes snoopy, i want to get it off clean.
Re: how do you remove a12 idle solenoid bracket #290626
04/17/09 09:26 AM
04/17/09 09:26 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I would take the working parts out of a donor solenoid and install them in the correct part number housing for your car instead of taking a bracket off the original. One way or the other you are having to disassemble both, might as well swap the inner working parts.
Re: how do you remove a12 idle solenoid bracket [Re: Dave Watt] #290627
04/17/09 10:26 AM
04/17/09 10:26 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Does the solenoid have a DR# stamped into it? Never seen one that way without a bracket.
Re: how do you remove a12 idle solenoid bracket [Re: ScottSmith_Harms] #290628
04/17/09 12:42 PM
04/17/09 12:42 PM
Soldotna,Alaska
RT_6_PakShaker Offline
super street
super street
Soldotna,Alaska
Scott
Gm used many applications that used a clamp type bracket that went over the barrel, same internals though.
I have bought several NOS solenoids without the bracket to repair the non working mopar type with bracket, pretty easy swap.
The 1969 GTO ram air solenoid is the same one that is used for the A-12.
Re: how do you remove a12 idle solenoid bracket [Re: RT_6_PakShaker] #290629
04/17/09 01:03 PM
04/17/09 01:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bruce, same DR#? Ok, yes I can see that happening. As far as what to do in his case, I think it would be pretty difficult to drill and replace his bracket spot welds (with convincingly accurate new welds) without dissassembling the unit first, I would recomend what the other poster suggested, remove the guts from both, replate the original, and put the new parts in the old case
Re: how do you remove a12 idle solenoid bracket [Re: RT_6_PakShaker] #290630
04/17/09 03:24 PM
04/17/09 03:24 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
I think the '69 GTO solenoid power spade comes out beneath the bracket, not to the right side. The top pic is a good reference if you are looking for solenoids.
dstryr, since 1986.
Re: how do you remove a12 idle solenoid bracket [Re: dstryr] #290631
04/17/09 04:11 PM
04/17/09 04:11 PM
Soldotna,Alaska
super street
super street
Soldotna,Alaska
Woops
My bad, your correct on that, sorry for being misleading.
Re: how do you remove a12 idle solenoid bracket [Re: RT_6_PakShaker] #290632
04/17/09 04:48 PM
04/17/09 04:48 PM
Snoopy Offline
Snoopy  Offline
SUPERSTOCKRACER
Does your original solenoid have any markings?
Does the new solenoid have any markings?
Re: how do you remove a12 idle solenoid bracket [Re: RT_6_PakShaker] #290633
04/17/09 04:51 PM
04/17/09 04:51 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The GM solenoid with the correct terminal location was used first on the 6cyl Overhead Cam Firebird.
Re: how do you remove a12 idle solenoid bracket [Re: Snoopy] #290634
04/18/09 10:15 PM
04/18/09 10:15 PM
Anonymous OP
Anonymous OP
SUPERSTOCKRACER
snoopy
i got a original 420 solenoid but just looked and the nos one w/o the bracket is a 421 one,i want to buy it and swap out internals, 62mxwagon might have a idea for me.thanks
Re: how do you remove a12 idle solenoid bracket #290635
04/18/09 11:13 PM
04/18/09 11:13 PM
Snoopy Offline
Snoopy  Offline
SSR,
That what I would do. That way you get new guts and the correct package.
Re: how do you remove a12 idle solenoid bracket [Re: Snoopy] #290636
04/18/09 11:49 PM
04/18/09 11:49 PM
Anonymous OP
Anonymous OP
SSR,
I want to get this done quickly, the idle solenoid really keeps the car running smoothly, i hope 62maxwgn can come through.
Re: how do you remove a12 idle solenoid bracket #290637
04/19/09 12:08 AM
04/19/09 12:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
In case you've never had one appart...
Re: how do you remove a12 idle solenoid bracket [Re: ScottSmith_Harms] #290638
04/19/09 12:09 AM
04/19/09 12:09 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Reproductions look the same on the outside .......But!
