Trans vent relocation #2904467
03/31/21 06:41 AM
03/31/21 06:41 AM
Chicago-area Illinois
4mopower Offline OP
4mopower  Offline OP
Went to install CSI trans shield and it is obstructed by the trans vent,
Would you notch the shield or relocate the vent?
The front pump vent is still there are 2 needed?
Thanks, John
Re: Trans vent relocation [Re: 4mopower] #2904473
03/31/21 07:22 AM
03/31/21 07:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Plug your vent. Relocate it here;
Doug
Re: Trans vent relocation [Re: dvw] #2904531
03/31/21 10:23 AM
03/31/21 10:23 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
On my 904 I pluged the front vent. Then I added the new vent hole near the front of the tail housing. I found that I also needed a hose with a puke tank
Re: Trans vent relocation [Re: DavidDean] #2904631
03/31/21 02:22 PM
03/31/21 02:22 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Modifying the shield will keep it from recerting if you had any interest in that.
I have a shield on mine and I have the vent in the tail housing near the speedometer drive.
68 Barracuda Formula S 340
Re: Trans vent relocation [Re: Bad340fish] #2904650
03/31/21 03:34 PM
03/31/21 03:34 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
You shouldn't need 2 vents and you shouldn't need to relocate the vent from the front unless you are running a trans brake. We installed our vent in the top of the tail shaft housing near where it meets the case and ran a rubber hose up to a vented puke tank. This way if it pushes fluid out the vent into the tank it can drain back down into the trans
Re: Trans vent relocation [Re: dvw] #2904653
03/31/21 03:43 PM
03/31/21 03:43 PM
an8sec70cuda Offline
Doug
iagree That's how mine is done.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Trans vent relocation [Re: dvw] #2904664
03/31/21 04:42 PM
03/31/21 04:42 PM
NC
440Jim Offline
440Jim  Offline
NC
Doug
I like that location (from the Griner instructions), and have used it successfully.
I also ground a little drainage in the rib below the new vent (yellow arrows).
Some cases have better or worse relief in this rib for drainage.
Re: Trans vent relocation [Re: 440Jim] #2904673
03/31/21 04:59 PM
03/31/21 04:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I plugged the original vent and moved mine to the tailshaft housing, just behind the park gear and down on the side a little. I used a brass 90° with a 1/8 npt male on one end and a 1/4" tube flare nut on the other, then bent a short piece of tube that points to the ground. I also fabricated a little shield that attaches inside the case with a couple small screws to prevent any splash from coming out the vent tube.
Re: Trans vent relocation [Re: dvw] #2904684
03/31/21 05:31 PM
03/31/21 05:31 PM
4mopower Offline OP
4mopower  Offline OP
Doug
Looks easy enough to do.
Thanks guys.
Re: Trans vent relocation [Re: cl440] #2904685
03/31/21 05:35 PM
03/31/21 05:35 PM
4mopower Offline OP
4mopower  Offline OP
I do have a brake, so your saying I should plug the front vent?
Re: Trans vent relocation [Re: 440Jim] #2904726
03/31/21 08:47 PM
03/31/21 08:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doug
I plug the pump on any race unit and relocate it there. Drain is a good idea. The rear support covers most of that area to help prevent oil from blowing out, I use the plastic rearend type vent with the cap. Never had one leak or blow oil out.
Cutting that shield will void the certification, and weaken it.
Re: Trans vent relocation [Re: dvw] #2904732
03/31/21 08:55 PM
03/31/21 08:55 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Doug
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Trans vent relocation [Re: W.I.N. Racing] #2904814
04/01/21 05:00 AM
04/01/21 05:00 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
same here vented to the tank located in the truck. overflow catch can.
Re: Trans vent relocation [Re: 4mopower] #2904834
04/01/21 07:51 AM
04/01/21 07:51 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Yes. Plug the front vent and relocate to the rear.
Re: Trans vent relocation [Re: dvw] #2904857
04/01/21 10:10 AM
04/01/21 10:10 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Doug
Dumb question time...can the relocation drilling/tapping be done to an already built transmission like OP's (or mine), or should the case be stripped beforehand??
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Trans vent relocation [Re: jughed] #2904866
04/01/21 10:36 AM
04/01/21 10:36 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've drilled aluminum stuff before using a vacuum cleaner. But in this case removing the tail shaft housing is a 5 minute deal. With it removed you can drill without issue. Make sure to stay forward of the gasket surface. When you drill, it will drill into the forward wall. Drill deep enough into the wall to get the tap down about 1/2"
Doug
Re: Trans vent relocation [Re: cl440] #2905340
04/02/21 12:04 PM
04/02/21 12:04 PM
4mopower Offline OP
4mopower  Offline OP
I do have a brake, so your saying I should plug the front vent? [/quote]
[/quote]
Ok. Great.
Thanks all for the info.
John.
Re: Trans vent relocation [Re: 4mopower] #2905560
04/02/21 08:08 PM
04/02/21 08:08 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
https://www.summitracing.com/parts/vpe-2669
I run this style fitting on my vent for my puke bottle
Re: Trans vent relocation [Re: 4mopower] #2907157
04/06/21 08:46 AM
04/06/21 08:46 AM
4mopower Offline OP
4mopower  Offline OP
We'll I didn't get to far with the CSI shield, the strap that wraps around the trans body interfers with the shift linkage and nss.
Has anyone else used this shield? How did you secure yours?
Re: Trans vent relocation [Re: 4mopower] #2907331
04/06/21 02:36 PM
04/06/21 02:36 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know what shifter you have but my strap goes between the NSS and the linkage bracket. I use a turbo action cheetah shifter. Its a little bunched up in there but it works. Unfortunately due to my exhaust system that area is impossible to photograph, I can't even tell you what it looks like just what it feels like LOL.
